[SOLVED] [bug] Checkboxes in vector catch window not synced
  • [SOLVED] [bug] Checkboxes in vector catch window not synced
    Attaching a gif to demonstrate this minor bug.
    I can select and deselect which faults to catch by selecting/de-selecting the checkbox.
    But I can also click on the red dot next to the fault name.
    If I click on the red dot, then after that the checkbox can still be used but the tick-marker does not change.
    Ubuntu 20.04
    Ozone v3.20c
    Best Regards,
    Daniel
    The post was edited 1 time, last by dannas ().
    Thank you for this report.
    We will look into this as soon as possible.
    This thread will be closed now. This can only be done by Admins and Moderators.
    So don't worry you did everything correctly by notifying us.
