[SOLVED] Feature Request / Optional Manual Reset of Execution Counters
  • [SOLVED] Feature Request / Optional Manual Reset of Execution Counters
    I'd like to request the option of a manual reset of the execution counters for the source and code profile windows. Per the manual, the counters reset automatically when the probe detects a reset (which is generally fine). However, I'm developing and testing a bootloader where resets are a normal part of the process and the execution counters are lost periodically when I'm trying to analyze the code coverage. I would like to be able to have the counters clear when Ozone writes the flash (obviously) and then only through some manual operation (e.g. keyboard shortcut, command line, menu option etc.)
    I've made a workaround that prevents the automatic counter reset by putting a breakpoint at the top of main() that has callback that just executes Debug.Continue(). However, I'd like something more explicit if possible (especially in the event that my breakpoint/continue workaround is not an intended behavior and gets "fixed" at some point), but it works for my purposes at the moment.
    Thanks for your help.
    Execution counters can already be reset manually (See Ozone Manual -> Chapter: Code Execution Counters).
    We added keeping execution counters across resets within a debug session to our wishlist.
  • Fabian,
    Thanks for your response. I suppose I could have phrased my request a bit better, but yes, my intent was the option of a manual reset that was mutually exclusive with the existing automatic reset of counters. I agree, though, that maintaining the counters on a debug session basis would fulfill the end result I was hoping for.
    Thanks for adding it to the list.
