I am using the J-Link probe to erase and flash the NXP LPC54608J512 microcontroller.
The J-Link version I am using is V6.82 and the target I use is LPC54608J512 (allow ECRP).
I get the message "Error while determining flash info (Bank @ 0x10000000)"
The problem is in erasing the SPIFI Flash but I have no SPIFI Flash connected to the microcontroller.
The problem is the same as this post:
forum.segger.com/index.php/Thr…xx-SPFI-Flashing-Problem/
Complete output:
J-Link>connect
Please specify device / core. <Default>: LPC54608J512
Type '?' for selection dialog
Device>?
J) JTAG (Default)
S) SWD
TIF>S
Speed>2000
Device "LPC54608J512 (ALLOW ECRP)" selected.
Connecting to target via SWD
DPIDR: 0x2BA01477
AP[0]: Core found
CoreSight components:
ROMTbl[0] @ E00FF000
ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
Cortex-M4 identified.
J-Link>erase
Erasing device (LPC54608J512 (allow ECRP))...
J-Link: Flash download: Total time needed: 1.926s (Prepare: 0.079s, Compare: 0.000s, Erase: 1.840s, Program: 0.000s, Verify: 0.000s, Restore: 0.005s)
****** Error: Failed to prepare RAMCode using RAM
ERROR: Erase returned with error code -1.
Thanks in advance,
Complete output:
J-Link>connect
Device>?
J) JTAG (Default)
S) SWD
TIF>S
Speed>2000
DPIDR: 0x2BA01477
AP[0]: Core found
J-Link>erase
Thanks in advance,
