[SOLVED] unable to program axf file using j-link commander
  • [SOLVED] unable to program axf file using j-link commander
    I am working on ARM Cortex M4 development board and using keil IDE for generating .axf output file. Instead of using using keil for flashing the generated outpu file(axf), i would like to use j-link commander.
    But whenever i try to program the M4 with the j-link commander(SWD) using loadfile, i am getting error as "File is of unknown/supported format". I understood that using J-link commander with loadfile, we can only program .hex, .bin, .mot,.srec.
    Is there any tool available to program the Cortex M4 with .axf file?? Please let me know
    Thanks and Regards,
    Satheesh Konduru
    The .axf file is a debug output file, intended for debugging and not for production/flashing the device.
    You could either use SEGGER Ozone for flashing it or convert it to a .bin file as already suggested.
    We will consider this thread as closed.
