[SOLVED] J-Link Read Low Voltage
  • [SOLVED] J-Link Read Low Voltage
    I am using a J-Link with Windows 10 version 6.80d
    Application log started
    - J-Flash V6.80d (J-Flash compiled Jun 26 2020 17:16:35)
    - JLinkARM.dll V6.80d (DLL compiled Jun 26 2020 17:16:09)
    I am using the 10pin adapter to communicate with the MCU.
    I am able to erase, and program the NXP MIMXRT1064xxx6a MCU.
    I am able to use the MCUXpresso IDE to download and debug my application.
    When I go to read sectors, I get
    WARNING: Supply voltage too low or too high, disconnecting target! VTarget = 0.909V or 0.0V
    I notice that the middle green light of the J-Link goes out when I initiate a read.
    Most of the time the read fails, but I am occasionally able to read 64K.
    If I read the entire chip, 4MB, 8 sectors are read before the 'supply voltage' error occurs. The middle green light is out during the 8 sector read.
    Any suggestions as to what is causing this behavior?
    From your post, it Looks like there is a power issue.
    Could you please make sure that
    - the J-Link is directly connected to the PC, and not to a USB-Hub
    - the Device is correctly powered externally.
    Are you using the J-Link you registered with?
    The S/N of that J-Link is from a unit from 2012 which is out of support and maintenance.
    We recommend to make use of our trade-in program:
    segger.com/purchase/trade-in-program/
    Fabian Federschmidt
