[SOLVED] How to set specific address to Program Section in flash_placement file
  • [SOLVED] How to set specific address to Program Section in flash_placement file
    Hi everyone,
    I am new to this and I need your advice and help. I am using Segger IDE to develop an aplication along with Nordic's SDK. I have to retain the value of one variable and do not be initialized after system reset. In order to achieve this I have to put RAM in retention and also to place my variable into a special program section in order to avoid initialization after reset. Digging around I found that in order to achieve this I have to add this variable into a program section called .non_Init that is under the RAM memory segment inside the flash_placement.xml file. In order to do this I have to declare the variable like this:
    1. static uint32_t my_variable __attribute__((section(".non_init")));
    See also the attachment with program section.
    I am correct so far?
    Nordic provides the API to put RAM in retention. More specifically I can put a particular RAM section in retention instead of the full RAM size (this will decrease my current consuption). However, to put a paticular RAM section in retention I need to know the memory address of my variable (in order to see in what RAM section it is located) and to ensure that it is not changing. How can I find the start address and size of .non_init section?
    Or is there any other approach I can follow? I am a beginner so please keep things simple :)
    Thanks in advance
    Nick
    The post was edited 1 time, last by Nikosant03 ().
  • Hello Nick,
    When using the GNU Linker you should see for all sections __start and __stop variables in the map file.
    You can find the .map file in the Output Files folder in the Project Explorer.
    There you should also find __non_init_start__.
    This is a pointer that points to the start of the non_init section.
    To use it in code you first have to declare it:
    1. extern unsigned long* __non_init_start__;
    and then you can use it e.g. in a printf().
    1. printf("noninit start is: 0x%x!\n", &__non_init_start__);
    I hope this helps.
  • Thank you very much Nino, it works perfect!! However I tried the same approach to find the __non_init_end__ address and the __non_init_size__ but the __non_init_size__ = 0x0
    The address range of .non_init section is dynamic? So, I suppose that there aren't any variables stored at .bss? That's why the __non_init_size__ is 0?
    I found that the start address of __non_init_start__ is 0x200006E4. This means that the first variable that I will add to the section .non_Init will have the address 0x200006E4 isn't it?
    2. extern unsigned long* __non_init_end__;
    3. extern unsigned long* __non_init_size__;
    4. NRF_LOG_INFO("noninit start is: 0x%x!\n", &__non_init_start__);
    5. NRF_LOG_INFO("noninit end is: 0x%x!\n", &__non_init_end__);
    6. NRF_LOG_INFO("noninit size: 0x%x!\n", &__non_init_size__);
    I found the section on the .map file. Very helpfull thanks!!
    1. *(.non_init .non_init.*)
    2. 0x0000000020004260 __non_init_end__ = (__non_init_start__ + SIZEOF (.non_init))
    3. 0x0000000000000000 __non_init_size__ = SIZEOF (.non_init)
    4. 0x0000000020004260 __non_init_load_end__ = __non_init_end__
    5. 0x0000000000000001 . = ASSERT (((__non_init_start__ == __non_init_end__) || ((__non_init_end__ - __RAM_segment_start__) <= __RAM_segment_size__)), error: .non_init is too large to fit in RAM memory segment)
    6. 0x0000000020004260 __heap_load_start__ = ALIGN (__non_init_end__, 0x4)
    Did you place anything in the non_init() section?
    I also get size 0 and end = start if the section is empty.
    Once I place something in there it shows the expected values.
    For example:
    4. volatile int _aArray[256] __attribute__((section(".non_init")));
    5. /*********************************************************************
    6. *
    7. * main()
    8. *
    9. * Function description
    10. * Application entry point.
    11. */
    12. int main(void) {
    13. int i;
    14. printf("noninit start is: 0x%x!\n", &__non_init_start__);
    15. printf("noninit end is: 0x%x!\n", &__non_init_end__);
    16. printf("noninit size is: 0x%x!\n", &__non_init_size__);
    17. for (i = 0; i < 100; i++) {
    18. _aArray[i] = i;
    19. printf("noninit start is: 0x%x!\n", _aArray[i]);
    20. }
    21. do {
    22. i++;
    23. } while (1);
    24. }
    Does it work for you as shown in the example?
  • Hi Nick,
