I cannot step through source c code, only disassembly. When I set a breakpoint in main() for example, the code breaks at the breakpoint but then if I "step into" it always goes to the disassembly window. I've been using embedded studio for a number of months without this problem, but it has now become an issue. It happens with both the debug and release builds, but only with this project. Other projects step through c code just fine.
[SOLVED] Cannot step through c code source, only disassembly
Usually this issue appears if source files are moved around and their absolute path on your filesystem changes so the debugger can't reference the disassembly with the source code anymore.
Could you try issuing a rebuild of your project instead of just a build? Does this improve the behaviour?
If not recheck the paths of your source files and see if they match the paths on your filesystem. Where possible we recommend using relative paths.
NinoPlease read the forum rules before posting.
Or you can contact us via e-mail. -
I tried the rebuild again and it didn't fix it. The source files have not moved and the paths match. I'm working with two related projects simultaneously, and now the second project is exhibiting the same problem whereas it was working just a day ago. This makes it tough to debug.
We currently have no other user pending with such issue so it is most likely it is related to your particular project setup.
Could you provide an example project for reproduction on an evaluation board?
I have the same issue with SEGGER Embedded Studio for ARM 5.10, it started happening after the update to SEGGER Embedded Studio for ARM 4.52c and the update to 5.10 did not fix the issue.
SEGGER seems to be unable to resolve any other files other than main.c.
I performed the steps above about rebuilding project (&solution) but it did not help.
The source files have not moved and the paths match -> this is also true for my project.
I am using relative paths throughout the project (as it is shared with other collaborators via git).
Interestingly, when I open the Breakpoints window and right-click the breakpoint and select "Go To Source Code", this:
- works fine when not in debugger mode
- does not work in debugger mode (there's no reaction whatsoever)
Any other hints that you could give to fix it? -
I tried downgrading to SEGGER Embedded Studio for ARM 4.16. This fixed the issue for me!
As my colleague Nino already inquired:
FabianPlease read the forum rules before posting.
I've had this issue once when I was moved a project from Windows to OS X; I had to delete the .emSession file and that seemed to fix the issue; no amount of cleaning and rebuilding prior to this fixed it.
Ok good to hear that you are up and running again.
Share
- Facebook 0
- Twitter 0
- Google Plus 0
- Reddit 0
