[SOLVED] Streaming Trace over SWD?
  • [SOLVED] Streaming Trace over SWD?
    We have a J-Trace PRO for Cortex-M and a FreeScale K64F board (Cortex M4) and would like to use Streaming Trace. SWO is connected (e.g. JLinkSWOViewerCLExe is working), but the TRACE_Dx and TRACE_CLKOUT signals are not accessible. The K64F manual implies that the instruction trace information can be routed out to the TRACE_SWO / JTAG_TDO. Is such a mode supported by Ozone (or any other debugger) please?
    Cheers,
    Pete.
  • Hello Pete,
    Such mode is not supported by our software due to its extreme speed limitations in comparison to the parallel trace with 4 data lanes.
    It would simply constantly create overflows on target device side due to the relatively low speed of the SWO pin.
    We recommend to use all Trace_Dx pins + Trace_Clkout if you are looking into streaming trace.
    For example our emPower eval board comes with trace pins populated and is based on the K66.
    segger.com/evaluate-our-software/segger/empower/
    A trace capable K64 board can be found here:
    wiki.segger.com/Tracing_on_NXP_Kinetis_MK64FN1M0
