Disable button pressed and unpressed effect
    • Disable button pressed and unpressed effect
      I wanted to disable button pressed and unpressed effect. The pressed and unpressed effect which is visible when button is pressed and released.
      Is there a way to do this?
      Anuj
      if you are using the default look of a button you can do the following:
      1. BUTTON_GetSkinFlexProps(&Props, BUTTON_SKINFLEX_PI_ENABLED);
      2. BUTTON_SetSkinFlexProps(&Props, BUTTON_SKINFLEX_PI_PRESSED);
      3. BUTTON_SetSkinFlexProps(&Props, BUTTON_SKINFLEX_PI_FOCUSED);
      4. BUTTON_SetSkinFlexProps(&Props, BUTTON_SKINFLEX_PI_DISABLED);
      5. BUTTON_Create(10, 10, 80, 20, GUI_ID_BUTTON0, WM_CF_SHOW);
      Please note that this can be globally for all buttons.
      You could alos overwrite the callback functon and draw the button only with one state. The same is true for setting a custom skinning function.
      Here is an example on how to overwrite the callback function:
      wiki.segger.com/BUTTON_-_Custom_(Sample)
      This one shows how to set a skinning routine:
      wiki.segger.com/Skinning_routine_(Sample)
