[SOLVED] Example Program 'Hello World' can't stop
  • [SOLVED] Example Program 'Hello World' can't stop
    I'm new to use J-link as the development board. Now I am using Spansion S6E2CC with J-link EDU.
    The board is connected, but when I just try the FM4 Samples files. The debugger is weird.
    I run the file "Hello world"
    which the source code is:
    int main(void) {
    int i;
    for (i = 0; i < 100; i++) {
    printf("Hello World %d!\n", i);
    do {
    i++;
    } while (1);
    the loop stuck in i=63 which shown in the attachment
    Do anyone know where the problem is?
    Thanks!
    The application does not stop. For printf this example uses SEGGER RTT which uses a buffer on the target as a I/O channel to J-Link.
    The default buffer is 1 kB in size. Depending on how fast the target device is this can be filled up faster than the J-Link reads it out.
    To avoid this you can e.g. increase the buffer size in the SEGGER_RTT_Conf.h file. Simply increase the value for BUFFER_SIZE_UP to e.g. 2048 and you should now see all 100 prints in the buffer.
