[ABANDONED] Jlink Commander Error: Failed to read back RAMCode for verification
  • [ABANDONED] Jlink Commander Error: Failed to read back RAMCode for verification
    I am using Jlink Commander V6.80. I've 2 boards with MKE15Z256.
    I can connect to the target device and erase/flash one hardware but trying to erase/flash the code on the other gives the error:
    ****** Error: Failed to read back RAMCode for verification.
    Failed to prepare for programming.
    Failed to download RAMCode!
    ERROR: Erase returned with error code -1.
    Attached log.
    However, if I select the micro MKE15Z128 on second hardware, I am somehow able to erase and flash bootloader file but not project file.
    Can anyone please suggest what may be the issue and how to resolve this.
    Thanks in advance.
    There is no such issue known to us related to this device.
    We are not able to reproduce this on our side with the latest J-Link J-Link Commander version (downloadable here):
    Setup:
    - FRDM-KE15Z evaluation board
    - J-Link Commander V6.802
    Are you using an evaluation board or custom hardware?
    If evaluation board: Which one?
    If custom hardware: Is this issue reproducible on an evaluation board?
    Is the same application + bootloader running on both boards?
    Could you provide us with a sample .hex file this issue is reproducible with on an evaluation board?
