[ABANDONED] Problem writing firmware to controller
    There is no issue related to NRF52832_XXAA known to us.
    Please find an example Embedded Studio project for the NRF52832_XXAA that is working out of the box on our side here:
    download.segger.com/Fabian/nRF52832_ESSampleProject.zip
    Could you please give it a try and tell us if it works on your side too?
    I re-uploaded the file.
    Our files are available ~48h when uploaded.
  • This project is working.
    I replaced "Hello World %d!\n" on "-> %d!\n" :
    .... //removed line
    -> 94!
    -> 95!
    -> 96!
    -> 97!
    -> 98!
    -> 99!
    My project is also working with this J-link.
    I can't understand why it didn't work.
    The only difference is that it upgraded the SeggerStudio to version 4.52c
    JLinkExe remained the same.
    • jlink-connect.txt
      (1.22 kB, downloaded 157 times, last: )
    • rtt_output.txt
      (658 Byte, downloaded 159 times, last: )
    I am not sure if I understood you correctly.
    You have two J-Links.
    With one J-Link both projects (yours and the one I sent you) are working.
    With the other J-Link, only our project is working.
    Is this correct?
    Is it still not working with one J-Link?
    If so, could you please provide us with the serial numbers of both J-Links?
    Are you using it in the exact same setup (same pc, same os, same board, same cables, etc.)?
