[SOLVED] Timeline not showing any of the task or systick events in graphical form
  • [SOLVED] Timeline not showing any of the task or systick events in graphical form
    I am using a Cortex M3 controller with FreeRTOS v10 and applied all the changes as per the below link
    wiki.segger.com/FreeRTOS_with_SystemView
    When I captured the recording, I am able to see all the systick ENTER/EXIT and task switching in the log.(attached : SystemView.PNG)
    But the timeline window is completely empty and not showing any of those events graphically.
    Is there any module which I have to enable in SystemView inorder to view in graphical form like this (attached : expected.png)
    I am also attaching the log which I captured (attached as log_SVDat.txt, please rename to log.SVDat to open in Segger SystemView).
    • log_SVDat.txt
      (653 Byte, downloaded 113 times, last: )
    It appears that the instrumentation of the FreeRTOS sources was not successful as your recording shows only Systick ISRs.
    I would expect at least one task to be running + the scheduler.
    Did you make sure that all necessary instrumentation steps have been applied?
    For more information see SystemView manual UM08027_SystemView.
    Hi Nino,
    If you look at the image : SystemView.png, you could see three things,
    1) Systick Interrupt ENTER and EXIT
    2) Hello task switch in and out
    3) Idle task
    In the log file which I have shared, there would be 3 times Hello task coming in and out.
    But none of these events are shown in the timeline.
    Is there any additional event which is missing and needed by timeline?
    We received your inquiry via our support system in parallel.
    To make sure no information gets lost between channels this thread will be closed now.
