the principle to program Norflash with flash loader
    • the principle to program Norflash with flash loader
      Now I want to program .bin to external Norflash with jflash, I want to create the customized flash loader, and I want to know how the flash loader works? The .bin can be programmed to external Norflash without programing code into the MCU, can you help to explain how the flash loader works?
      thanks!
      J-Link supports two programming modes. Direct and indirect.
      wiki.segger.com/Programming_External_SPI_Flashes
      If you want to do direct programming, all you have to do is to wire the SPI Flash to the J-Link debug interface as documented and you are good to go.
      The following Flashes will work automatically:
      segger.com/products/debug-prob…es/supported-spi-flashes/
      Other similar Flashes can be added manually using J-Flash SPI:
      segger.com/products/debug-probes/j-link/tools/j-flash-spi/
      If you want to do indirect programming via the MCU QSPI Flash loader or manually via GPIOs you can use our open Flash loader interface and create your own Flash loader:
      wiki.segger.com/Open_Flashloader#Open_Flashloader
    • HI Nino
      Thanks for your comments. can you help to explain the meaning of "RAMCode"? I can create a Template_CortexM.elf with SEGGer Embedded Studio, if is the .elf the "RAMCode"? If so, can you help to provide a demo to program QSPI flash? Such as ST_STM32F469I_Disco_QSPI.elf source code. I noticed that SEGGER can support it default.
      Yes the resulting application is the RAMCode.
      Regarding the demo project for the STM32F469_Discovery board, please note that we can't share this sources in public. But you can request this via our support system. Simply open a ticket in the J-Link support group requesting the sources.
      How to open a ticket is explained in my signature.
      Our support system works via e-mail on the customer side. On Monday my colleague Sebastian gave you an answer on your ticket. We received no bounce message from your mail server so the message should have received your inbox.
      We recommend to check your spam folder. If you can't find the e-mail from our @segger.com domain we recommend to get in contact with your IT department about the missing e-mails.
