[SOLVED] RTT with Keil Compiler 6
  • [SOLVED] RTT with Keil Compiler 6
    I have recently ported from Keil compiler v5.16 to Keil compiler v6.13. On doing so, the porting was successful except for the fact that I can no more see deubg prints on RTT Viewer. On checking, I understood that "SEGGER_RTT_Syscalls_KEIL.c" expects __CC_ARM defination which compiler 6 does not use. I tested it with latest version of files but no luck.
    Can someone suggest a solution?
    Other details: Controller--> ARM Cortex M4 based.. IDE--> Keil uVision, system--> Windows.
    Try using __ARMCC_VERSION instead.
    We will update the RTT sources accordingly with our next software package release.
