[SOLVED] MAC7111 locked after Chip Erase
  • [SOLVED] MAC7111 locked after Chip Erase
    after Chip Erase JLINK cannot connect to the MAC7111 device any more.
    This is known issue however I havent found any working solution howto perform JTAG recovery.
    When I use Target->Manual Programming->Unsecure Chip it returns "Chip unsecured succesfully" but still cannot connect.
    In the command line the "Unlock Kinetis" does not work since target is not connected.
    I would be grateful for any ideas or hints.
  • I was finally able to connect to the target after lowering JTAG speed from 4000kHz to 400kHz.
    It is odd because normally when there is a program in the flash the target communicates even at 4000kHz. This issue only occurs after Chip Erase command.
    Unlock Kinetis may only work for NXP Kinetis target devices and not the MAC7xxx series.
    On many legacy ARM7/9 target devices debug interface speeds are not consistent. So it is possible that this target device has such inconsistency when the device is locked.
    However this is no issue related to J-Link but rather a target specific topic. For more information we recommend contacting the silicon vendor if there is known behavior like this.
