[SOLVED] Ozone: Debug at power-on conditions
  • [SOLVED] Ozone: Debug at power-on conditions
    we have a problem where we need to debug the conditions at very close time to the power-on state.
    If we switch on the device and then connect with Ozone manually, it is already too late.
    Is there a way to have Ozone start the debugging session automatically when the J-Link Pro detects a connected device?
    Or can the J-Link Pro maybe cache some data before Ozone connects to it?
    Maybe a stupid question but after two days of fiddling with this and on a Friday evening, my brain is fried. :D
    Cheers
    The Arm debug interface is unfortunately not designed to catch such power on issues directly.
    So proper debugging as you know it with J-Link usually will not work. The only viable way is to write debug messages or variable values to some buffer on target side that gets written after startup. Then you can attach with J-Link at a later point and read out the data buffer.
    For a minimal footprint and maximal performance of such implementation we recommend RTT:
    segger.com/products/debug-prob…about-real-time-transfer/
    Great to hear that you are up and running.
    We will consider this thread as closed now.
