Problems with QR Code [Solved]
    • Problems with QR Code [Solved]
      Hello everybody,
      I have a problem with drawing QR Codes.
      I orientated myself on your example "GUI_QRCode.c" but it does not draw anything. I tried to draw a rectangle/polygon instead but this also fails. What could it be?
      Graphs, tables and so on are working fine.
      Thank you very much
      1. static void _cbScreen5(WM_MESSAGE * pMsg)
      2. {
      3. WM_HWIN hItem;
      4. GUI_HMEM hQR;
      5. int NCode,Id;
      6. switch (pMsg->MsgId)
      7. {
      8. case WM_INIT_DIALOG:
      9. hItem = pMsg->hWin;
      10. WINDOW_SetBkColor(hItem, GUI_WHITE);
      11. hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_50);
      12. TEXT_SetTextAlign(hItem, TEXT_CF_LEFT);
      13. TEXT_SetTextColor(hItem, GUI_BLUE);
      14. TEXT_SetFont(hItem, GUI_FONT_24B_1);
      15. hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_BACK_MENU_5);
      16. BUTTON_SetText(hItem, "Menu");
      17. BUTTON_SetDefaultSkin(BUTTON_SKIN_FLEX);
      18. hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_SCREEN_5);
      19. BUTTON_SetText(hItem, "Screen 2 ");
      20. GUI_SetColor(GUI_BLACK);
      21. hQR = GUI_QR_Create("www.google.com", 5, GUI_QR_ECLEVEL_Q, 0);
      22. GUI_QR_Draw(hQR, 10, 10);
      23. break;
      24. case WM_NOTIFY_PARENT:
      25. Id = WM_GetId(pMsg->hWinSrc);
      26. NCode = pMsg->Data.v;
      27. switch(Id) {
      28. case ID_BUTTON_SCREEN_5: // Notifications sent by 'Iconview'
      29. switch(NCode)
      30. {
      31. case WM_NOTIFICATION_CLICKED:
      32. break;
      33. case WM_NOTIFICATION_RELEASED:
      34. WM_HideWindow(pMsg->hWin);
      35. WM_ShowWindow(hScreen2);
      36. break;
      37. }
      38. break;
      39. case ID_BUTTON_BACK_MENU_5:
      40. switch(NCode)
      41. {
      42. case WM_NOTIFICATION_RELEASED:
      43. WM_HideWindow(pMsg->hWin);
      44. WM_ShowWindow(hDialog);
      45. break;
      46. }
      47. break;
      48. }
      49. default:
      50. WM_DefaultProc(pMsg);
      51. break;
      52. }
      53. }
      it should work when calling GUI_QR_Draw() in a WM_PAINT case instead of WM_INIT_DIALOG. In fact, you should only draw inside of a WM_PAINT case when using the Window Manager, or otherwise it won't work properly.
      Florian
