Embedded Studio - problem whith import IAR project
    • Embedded Studio - problem whith import IAR project
      New
      Hi!
      I evaluate Segger Embedded Studio. I downloaded lastest version (4.52c), impoted my IAR project, starting build and and got a lot of errors related whith preprocessor. For example: in IAR preprocessor I defined:
      MBEDTLS_CONFIG_FILE="protocol/bluetooth/ble_stack/inc/soc/mbedtls_config.h"
      RTOS_DEBUG_MODE=DEF_ENABLED - where DEF_ENABLED defined in .h file
      Segger ES imported this settings, but Segger ES not accept their meaning. Could you explain please: whether it is possible to make such preprocessor defines in Segger ES?
    • New
      A generic guide on how to port project from IAR to ES can be found here:
      wiki.segger.com/Port_Projects_…kbench_to_Embedded_Studio
      Not all information can be translated from IAR during the import process e.g. some preprocessor options.
      You can add them manually via Embedded Studio project options under Preprocessor->Preprocessor Definitions
