failed to create customized flash loader
    • failed to create customized flash loader
      J-link community,
      I followed wiki.segger.com/Open_Flashloader to create a customized flash loader. The SOC is nearly same as the SiFive FE310, except the RAM/Flash address are different.
      QSPI flash controller address: 0x15000
      QSPI flash XIP address: 0x20000
      Attached is my project for the flash loader. In the debug configuration, I can see the flash content are correctly loaded. But when I create the Release version and try it, I got the error:
      J-Link>r
      Reset delay: 0 ms
      Reset type Normal: Resets core & peripherals using <ndmreset> bit in <dmcontrol> debug register.
      RISC-V: Performing reset via <ndmreset>
      J-Link>loadfile D:/source/n100-sdk/software/hello_world/hello_world.hex
      Downloading file [D:/source/n100-sdk/software/hello_world/hello_world.hex]...
      Unspecified error -1
      J-Link>erase
      Erasing device...
      Erasing done.
      when I follow the "Troubleshoot" on the same page, by excluding codes related to flash operation, J-link commander will exit automatically when connect the target.
      It is my first time to write a flash loader. There may be some something wrong with my understanding.
      /Li
