[SOLVED] I can view RTT message on "Debug Terminal" in emStudio, but can't see the message with Jlink RTT viewer
  • [SOLVED] I can view RTT message on "Debug Terminal" in emStudio, but can't see the message with Jlink RTT viewer
    I am trying J-Link RTT on Nuclei N101 core. Now I can successfully get the RTT message from function SEGGER_RTT_printf by "Debug Terminal" in emStudio. But if I use J-Link RTT viewer, I can't see any messages at all. The RTT viewer works well with another MCU STM32F103.
    Here is the output from RTT viewer log, there is nothing from the ternimal window.
    LOG: J-Link RTT Viewer V6.80c: Logging started.
    LOG: Terminal 0 added.
    LOG: Connecting to J-Link via USB...
    LOG: Device "N101" selected.
    LOG: ConfigTargetSettings() start
    LOG: ConfigTargetSettings() end
    LOG: TotalIRLen = 5, IRPrint = 0x01
    LOG: JTAG chain detection found 1 devices:
    LOG: #0 Id: 0x11010A6D, IRLen: 05, Unknown device
    LOG: Debug architecture:
    LOG: RISC-V debug: 0.13
    LOG: AddrBits: 7
    LOG: DataBits: 32
    LOG: IdleClks: 7
    LOG: Memory access:
    LOG: Via system bus: No
    LOG: Via ProgBuf: Yes (2 ProgBuf entries)
    LOG: DataBuf: 4 entries
    LOG: autoexec[0] implemented: Yes
    LOG: Detected: RV32 core
    LOG: CSR access via abs. commands: No
    LOG: Temp. halted CPU for NumHWBP detection
    LOG: HW instruction/data BPs: 2
    LOG: Support set/clr BPs while running: No
    LOG: HW data BPs trigger before execution of inst
    LOG: RTT Viewer connected.
    LOG: RTT is running in stop mode: wiki.segger.com/RTT#Stop_mode
    It is running on stop mode, it should work. I had suspect the problem is related to emStudio. But after I shutdown the emStudio, I still got nothing. I am sure the program is running, as I can get some messages from the UART port.
    /Li
    Did we enter a wrong value in the device xml or was the related entry added by yourself?
  • Fabian,
    The xml from J-link dll is wrong. I have informed the chip maker Nuclei about the problem. And they will contact your company soon.
    Nuclei N101, according to the doc I got:
    QSPI flash controller address: 0x15000
    QSPI flash XIP address: 0x20000-0x3FFFF
    RAM address: 0x80000-0x9FFFF.
    I think Nuclei will give you the authoritative details.
    /Li
  • Hi Li,
    Nuclei contacted us regarding this.
    We will fix this issue as soon as possible.
    Stay up-to-date regarding J-Link:
    segger.com/notification/subscribe.php?prodid=7,94
