SystemView STM32F7508-DK board
      Any chip that is supported by J-Link and supports background memory access can be used fully with SystemView:
      So yes, the STM32F750N8 is supported.
    • Hello, thanks for the response.
      The board is supported by J-link, but taking in consideration that by default the board is using an ST-link for debug and I have to reflash it using STLinkReflash in order to use it as J-link, does anyone test the STLinkReflash and J-Link OB firmware with this evaluation board ?
      thanks!
      All tested boards can be found here:
      segger.com/products/debug-prob…j-links/st-link-on-board/
      The one you are using seems not to be among them, but as long as the ST Link is below v3, you should be fine.
      You can of course also connect to the device via an external J-Link.
    • New
      Hi, I've tested with an external J-link, did not fix the issue. Does anyone by any chance tried to use the systemview using the following configuration: FreeRTOS v10.2.1, gcc compiler and STM32 board with a Cortex-M7 mcu?
      Is there an example? Because I've follow the steps described in documentation and did not managed to get it work, I am not receiving the SEGGER_SYSVIEW_COMMAND_ID_START event.
