[SOLVED] Automatic versioning with preprocessor macros
  • [SOLVED] Automatic versioning with preprocessor macros
    we are using Segger Embedded Studio for developing software with Nordic microcontrollers. I would like to automatically add a string, containing the build configuration name (e.g. "Release") and the git hash of our git repository, to the preprocessor definitions.
    As an Example what I mean: In our eclipse projects we use the "shell" command to create preprocessor definitions that hold the git has and branch names. This would look like this:
    VERSION_INFO="${ConfigName}_$(shell git rev-parse --abbrev-ref HEAD)_$(shell git rev-parse --short HEAD)"
    The result is a string with a value like that: "Release_master_1ab3f12"
    Is there an equivalent in Segger Embedded Studio to the Eclipse "shell" command? I could not find anything in the Embedded Studio documentation. Or is there another solution how to get the Git Has as a string that can be used globally in our software?
    Thanks and best regards
    Bjoern
  • Hello Bjoern,
    To pass e.g. versioning information during your build process we recommend using project macros which then can be defined as a preprocessor define:
    studio.segger.com/ide_project_macros.htm
    A thread discussing something similar can be found here:
    [SOLVED] User defined macros expansion
    To start your builds automatically via command line you can use emBuild:
    studio.segger.com/emBuild_building_with_a_project_file.htm
  • Hi Nino,
    thanks for the quick reply. I tried to use the project macro but I don't think I understood correctly how to use the project macros. I did three things:
    1. I added the git command to parse the repo has as a project macro:
    Under: Project->Options->Code->Build->Projec Macros
    I added: GIT_MACRO=git rev-parse --abbrev-ref HEAD
    2. I added a preprocessor define using the macro:
    Under: Project->Options->Code->Preprocessor->Preprocessor Definitions
    I added: GIT_REV=$(GIT_MACRO)
    3. I tried to use the preprocessor definition in my code:
    static uint8_t testString[] = GIT_REV;
    If I do all that, then I get the compiler error: "'git' undeclared here (not in a function)"
    How do I tell Embedded Studio, that it should execute "git" in a command line? I did not find anything in the documentation.
    Bjoern
    The post was edited 5 times, last by bjoernSchmitz ().
  • Hi Bjoern,
    Unfortunately, it is not possible to set macros per shell.
    The only way we can think about how to achieve this would be via pre-build command (or via Combining Project),
    which calls a script to create a header with the variable in it.
    Would that be an option for you?
  • Hi Fabian,
    thanks for the reply, that's what I wanted to know. I also thought about the solution with a script executed during pre-build process, but was hoping there is an easier solution. We will choose this option then, as you suggested. You can mark this thread as solved.
    Bjoern
  • Hi Bjoern,
