[SOLVED] RTT and FreeRTOS
  • [SOLVED] RTT and FreeRTOS
    Hi folks,
    We are using JLink Plus with the SAMD21E16. Wondering if special configuration for RTT is necessary as it's causing some kind of deadlock or crash when used inside a Task.
    Consider this snippet of code
    1. void xBatteryManagementTask(void *p){
    2. uint16_t battery_voltage = 0;
    3. for(;;){
    4. bq_start_adc();
    5. battery_voltage = bq_get_adc_reg(ADC_VBAT);
    6. SEGGER_RTT_printf(0, "Battery voltage %umV", battery_voltage);
    7. if( battery_voltage < 12000){
    8. gpio_set_pin_level(RED_LED, false);
    9. }
    10. os_sleep(1000);
    11. }
    12. }
    The battery voltage message is received in the RTT viewer the first time, but after that the application goes into deadlock or some type of error condition. Heartbeat LED no longer toggles. I tried debugging with Ozone but it's causing a hard fault on connection.
    The most common reason for such an issue is the following:
    FreeRTOS does not use a scheduler but interrupts to manage its tasks.
    If you have a task using RTT this can lead to problems as the following example explains.
    The main task calls SEGGER_RTT_printf(), which is locking RTT while writing the data to the buffer.
    At the same time, a different task is called via interrupt before SEGGER_RTT_printf() unlocks RTT again.
    The task then calls SEGGER_RTT_printf(), which is then waiting for SEGGER_RTT_printf() from the main task to unlock RTT.
    Unfortunately, the interrupt task can never return, since it is waiting for the RTT lock to open, resulting in a deadlock.
    To make sure that such a thin is not happening is the user's responsibility.
    Regarding the Ozone hard fault issue:
    Could you please open a separate Thread for that?
  • Thanks for the response, Fabian.
    We will work on thread-safe usage of RTT. For now, it is working again. We discovered we were not using the RTOS compatible I2C driver provided by our vendor. That is what was causing the problems.
    As we add RTT_printfs() to other tasks we will make sure the code is thread-safe.
    Thanks again.
