Overwriting GUIBuilder Window Creation Callback
    • Overwriting GUIBuilder Window Creation Callback
      Hello
      How Can I overwrite GUIBuilder window creation callback. I want to draw a window with gradient background color.
      I tried the following modification on GUIBuilder output, but i did not work.
      (Compiler warning is included at the bottom of code)
      C Source Code: Gradient window
      1. /*********************************************************************
      2. * *
      3. * SEGGER Microcontroller GmbH & Co. KG *
      4. * Solutions for real time microcontroller applications *
      5. * *
      6. **********************************************************************
      7. * *
      8. * C-file generated by: *
      9. * *
      10. * GUI_Builder for emWin version 5.32 *
      11. * Compiled Oct 8 2015, 11:59:02 *
      12. * (c) 2015 Segger Microcontroller GmbH & Co. KG *
      13. * *
      14. **********************************************************************
      15. * *
      16. * Internet: www.segger.com Support: support@segger.com *
      17. * *
      18. **********************************************************************
      19. */
      20. // USER START (Optionally insert additional includes)
      21. // USER END
      22. #include "DIALOG.h"
      23. /*********************************************************************
      24. *
      25. * Defines
      26. *
      27. **********************************************************************
      28. */
      29. #define ID_WINDOW_0 (GUI_ID_USER + 0x00)
      30. // USER START (Optionally insert additional defines)
      31. // USER END
      32. /*********************************************************************
      33. *
      34. * Static data
      35. *
      36. **********************************************************************
      37. */
      38. // USER START (Optionally insert additional static data)
      39. static void _cbWin0(WM_MESSAGE * pMsg) {
      40. GUI_RECT Rect;
      41. switch (pMsg->MsgId) {
      42. case WM_PAINT:
      43. WM_GetClientRect(&Rect);
      44. GUI_DrawGradientH(Rect.x0, Rect.y0, Rect.x1, Rect.y1, GUI_RED, GUI_BLUE);
      45. break;
      46. default:
      47. WM_DefaultProc(pMsg);
      48. break;
      49. }
      50. }
      51. // USER END
      52. /*********************************************************************
      53. *
      54. * _aDialogCreate
      55. */
      56. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
      57. { WINDOW_CreateIndirect, "Gradient", ID_WINDOW_0, 0, 0, 320, 240, 0, 0x0, _cbWin0 },
      58. // USER START (Optionally insert additional widgets)
      59. // USER END
      60. };
      61. /*********************************************************************
      62. *
      63. * Static code
      64. *
      65. **********************************************************************
      66. */
      67. // USER START (Optionally insert additional static code)
      68. // USER END
      69. /*********************************************************************
      70. *
      71. * _cbDialog
      72. */
      73. static void _cbDialog(WM_MESSAGE * pMsg) {
      74. // USER START (Optionally insert additional variables)
      75. // USER END
      76. switch (pMsg->MsgId) {
      77. // USER START (Optionally insert additional message handling)
      78. // USER END
      79. default:
      80. WM_DefaultProc(pMsg);
      81. break;
      82. }
      83. }
      84. /*********************************************************************
      85. *
      86. * Public code
      87. *
      88. **********************************************************************
      89. */
      90. /*********************************************************************
      91. *
      92. * CreateGradient
      93. */
      94. WM_HWIN CreateGradient(void);
      95. WM_HWIN CreateGradient(void) {
      96. WM_HWIN hWin;
      97. hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
      98. return hWin;
      99. }
      100. // USER START (Optionally insert additional public code)
      101. // USER END
      102. /*************************** End of file ****************************/
      103. //*************************************************
      104. Compiler output:
      105. ->Warinigs (1 Item)
      106. initialization makes integer from pointer without a cast [-Wint-conversion]
      107. ->Infos (1 Item)
      108. (near initialization for '_aDialogCreate[0].NumExtraBytes')
      109. **************************************************/
      Thanks in advance
      the GUI_WIDGET_CREATE_INFO structure is defined as follows:
      1. struct GUI_WIDGET_CREATE_INFO_struct {
      2. GUI_WIDGET_CREATE_FUNC * pfCreateIndirect;
      3. const char * pName; // Text ... Not used on all widgets
      4. I16 Id; // ID ... should be unique in a dialog
      5. I16 x0; // x position
      6. I16 y0; // y position
      7. I16 xSize; // x size
      8. I16 ySize; // y size
      9. U16 Flags; // Widget specific create flags (opt.)
      10. I32 Para; // Widget specific parameter (opt.)
      11. U32 NumExtraBytes; // Number of extra bytes usable with <WIDGET>_SetUserData & <WIDGET>_GetUserData
      12. };
      As last parameter you passed a pointer to a callback function, where the number of extra bytes to be allocated should be. So instead of _cbWin, you can just pass 0 as last parameter.
      The WINDOW widget in your _aDialogCreate structure is not a separate window widget, it is the dialog. So, to draw a gradient you don't need another callback, you can just copy the WM_PAINT case from _cbWin0 into the _cbDialog callback.
      Florian
