Difference between -setcpuidcode and -setrxidcode instructions in Jflash.exe
    • Difference between -setcpuidcode and -setrxidcode instructions in Jflash.exe
      Hello
      I want to create a batch file that unlocks one microcontroller before writing , but I'm not sure how to do it.
      Reading the manual I saw two options: -setcpuidcode and -setrxidcode. This is what I'm trying to do, but it's not working because JFLASH always shows the id code window:
      1. %path_JFLASH_exe% -openprj%path_FILES_JFLASH% -setrxidcode%XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX% -startapp -hide -exit
      - It's not clear to me after reading the description what the difference is between -setcpuidcode and -setrxidcode.
      - Does -setrxidcode go before or after -startapp?
      - Does the id code should go between percentage signs?
      The post was edited 2 times, last by Hardwariano ().
      There is no difference between the handling of these two commands.
      This is because of legacy/backwards compatibility reasons.
      The order of the command line options does not matter.
      As described in the documentation, it does not.
      Regarding the issue:
      Could you please send us the whole output of the J-Flash log window?
    • Hello Fabian,
      I don't know if I'm doing anything wrong, but it's not working. Every time I try to unlock the microcontroller using -setcpuidcode the ID Code verification window appears and I have to unlock it manually.
      Maybe I didn't understand the functionality of -setcpuidcode and -setrxidcode?
      Attached are the logs.
      Regards.
      • jflash Log.txt
        (2.44 kB, downloaded 6 times, last: )
      • jlink log.txt
        (5.24 kB, downloaded 6 times, last: )
    • New
      On our side, the ID dialog works fine (meaning it does not show up when an ID is passed via command line), but we are experiencing an issue with unlocking this device.
      I will coma back to you as soon as we have news about this.
