[SOLVED] Ozone - Views configuration not fully restored after Exit
  • [SOLVED] Ozone - Views configuration not fully restored after Exit
    in Ozone v3.20a when I have several stacked views, on restart Ozone forgets what view in a stack was at the top.
    See the picture:
    I usually have the Data Sampling and Watched Data tabs on top but when I exit and restart Ozone, it's always the rightmost tab that's on top. I _think_ in the past the selected tab was restored for the next session. Not sure about that, though.
    It feels like it should, though.
    Reordering the tabs to the ones I want to see are one the right does not work either because the order of the tabs is also not restored.
    Cheers
    The post was edited 1 time, last by icwiener ().
    The reported behaviour was reproducible and will be improved.
    A quick test through numerous Ozone versions shows that Ozone always behaved this way.
    thanks for reproducing.
    I wasn't sure about the earlier versions. It just stumbled across it the other day, probably because I opened more views.
    Cheers
