[SOLVED] Ozone - Path to SVD file not updated on update
  • [SOLVED] Ozone - Path to SVD file not updated on update
    .jdebug files are created with an entry containing an absolute path in it.
    Project.AddSvdFile ("C:/Program Files/SEGGER/Ozone V3.10j/Config/CPU/Cortex-M4F.svd");
    When I now install Ozone v3.20a and remove v3.10j and then open the .jdebug file in the newer Ozone, the path is invalid but I do not get an error message.
    When I then save the file with File -> Save project as... the path is not updated, so it remains invalid.
    Maybe it is better to use a runtime variable to determine the position of the ozone executable and go from there.
    Using paths relative to the .jdebug file when it comes to the debugee exe file, might also be a good idea. That way, a debugging project file could work on different computers.
    Cheers
    We will add this to the improvements list for Ozone.
    This is expected as the path is set only once during project creation via the project wizard.
    That was the default and is the default again for V3.20 and later. So it does not only work on different computers but on different Ozone versions as well.
    looking at v3.20a I can see that
    1) the install path is not versioned anymore and
    2) the SVD path in the .jdebug file uses a variable.
    So, I guess that should fix the SVD path problem. (Not sure if there was a real problem though since I did not see any negative effects of the path being invalid)
    The project path, however, is still an absolute path.
    Project.AddPathSubstitute ("C:/path/to/project", "$(ProjectDir)");
    Is this still planned for the future or made absolute on purpose?
    Cheers
    This is on purpose, but the reason is not Ozone. Rather the compilers output debug information in absolute paths usually.
    Ozone only works with the output file so if you move your elf file in your file system around without rebuilding the application, the paths will become incorrect and Ozone can no longer reference the source files to the code.
    That is on of the reasons why Project.AddPathSubstitute exists so such projects with absolute paths can be made portable.
