[SOLVED] Ozone - Changing Sampling Freq. does halt the timeline sometimes
  • [SOLVED] Ozone - Changing Sampling Freq. does halt the timeline sometimes
    in Ozone v3.20a when I start a debugging process and then change the Sampling Freq: in the Data Sampling window, the Timeline view just freezes. Changing the frequency back to the original one lets the Timeline run again. It's not always the same frequency that freezes the timeline. The one I start the debugging process with works fine but then trying the other frequencies shows two or sometimes three working, the other ones freeze the timeline.
    Can you reproduce this?
    /edit: I just found out that it is just every second selection that works. So the starting frequency works, the next one doesn't, the next one does, the next one doesn't ... regardless of the order in which you click them.
    Cheers
    The post was edited 2 times, last by icwiener ().
    The reported behaviour is reproducible and will be improved.
