I am using the touch calibrate sample emWin has provided. It works perfectly fine the first time I call touchCalibrate function. Once the touch is calibrated, I use Windows Manager to create a window with couple buttons.
When a button on this screen is touched, I would like to calibrate the touchscreen again. So I am trying to use the same touchCalibrate function I used before, except now that I have a window dialog, things have to be rearranged to work with a window.
Question: Is there a way to disable windows manager and be able to enable it once the touchscreen calibration is completed?
Any help is really appreciated.
Thanks and regards,
BMD
Thanks and regards,
BMD
