J-link EDU mini DLL ERROR
    • J-link EDU mini DLL ERROR
      New
      Hello everyone,
      I just bought a J-link EDU mini in order to train myself to bootload an Adafruit Feather nRF52840 Express because I want to put the nRF shield on a card to learn how to use BLE. So I downloaded the J-link Software and documentation pack and also the commands line tools from nordicsemi.com, but I can't erase the bootloader on the card, I always have the same error about DLL.
      I uninstall and reinstall softwares and drivers at least 3 times and I tryed on my Linux PC too, same issue.
      You can see the log.log here:
      2020-May-19 15:49:25 --------------------------------------------------------------------------------
      2020-May-19 15:49:25 nrfjprog -f nrf52 --eraseall --log
      2020-May-19 15:49:25 nrfjprog version 10.8.0
      2020-May-19 15:49:25 nRF_logger_open
      2020-May-19 15:49:25 nRF_logger_open: nRFJProg logger opened to callback at address 0X7FF675093410
      2020-May-19 15:49:25 nRF_open_dll
      2020-May-19 15:49:25 nRF_open_dll: Load library at "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\JLINKARM_NRF52_NRFJPROG.dll".
      2020-May-19 15:49:25 . nRF52_logger_open
      2020-May-19 15:49:25 . nRF52_logger_open: nRFJProg logger opened to callback at address 0X7FF88B22E520
      2020-May-19 15:49:25 . nRF52_open_dll
      2020-May-19 15:49:25 . . Segger_logger_open
      2020-May-19 15:49:25 . . Segger_logger_open: nRFJProg logger opened to callback at address 0X7FF875E02A90
      2020-May-19 15:49:25 . . Segger_open_dll
      2020-May-19 15:49:25 . . Segger_open_dll: Load library at "C:\\Program Files (x86)\\SEGGER\\JLink\\JLink_x64.dll".
      2020-May-19 15:49:25 . . . Segger_dll_version
      2020-May-19 15:49:25 . . Segger_set_core_data
      2020-May-19 15:49:25 nRF_enum_emu_snr
      2020-May-19 15:49:25 . nRF52_enum_emu_snr
      2020-May-19 15:49:25 . . Segger_enum_emu_snr
      2020-May-19 15:49:25 . . . Segger_enum_emu_snr
      2020-May-19 15:49:25 . . . . Segger_get_num_emus
      2020-May-19 15:49:25 nRF_connect_to_emu_with_snr
      2020-May-19 15:49:25 . nRF52_connect_to_emu_with_snr
      2020-May-19 15:49:25 . . Segger_connect_to_emu_with_snr
      2020-May-19 15:49:25 . . . Segger_is_connected_to_emu
      2020-May-19 15:49:25 . . . Segger_connect_to_emu_with_snr
      2020-May-19 15:49:25 . . . . Segger_connect_to_emu_without_snr
      2020-May-19 15:49:25 . . . . Segger_connect_to_emu_without_snr: Segger logging enabled with callback at 0x140705106243120.
      2020-May-19 15:49:25 . . . . Segger_is_connected_to_emu
      2020-May-19 15:49:25 . . . . Segger_is_connected_to_emu: JLink INFO T1D70 000:088.351
      2020-May-19 15:49:25 . . . . Segger_is_connected_to_emu: JLink INFO JLINK_IsOpen()
      2020-May-19 15:49:25 . . . . Segger_is_connected_to_emu: JLink INFO T1D70 000:089.083
      2020-May-19 15:49:25 . . . . Segger_is_connected_to_emu: JLink INFO - 1.089ms returns 0x01
      2020-May-19 15:49:25 . . . Segger_read_debug_port_register: JLink INFO T1D70 000:089.808
      2020-May-19 15:49:25 . . . Segger_read_debug_port_register: JLink INFO JLINK_Lock()
      2020-May-19 15:49:25 . . . . Segger_read_debug_port_register
      2020-May-19 15:49:25 . . . . . Segger_coresight_configure
      2020-May-19 15:49:25 . . . . . Segger_coresight_configure: JLink INFO T1D70 000:091.247
      2020-May-19 15:49:25 . . . . . Segger_coresight_configure: JLink INFO JLINK_CORESIGHT_Configure()
      2020-May-19 15:49:25 . . . . . Segger_coresight_configure: JLink INFO T1D70 000:192.373
      2020-May-19 15:49:25 . . . . . Segger_coresight_configure: JLink INFO - 103.185ms returns 0
      2020-May-19 15:49:25 . . . . Segger_read_debug_port_register: JLink INFO T1D70 000:196.261
      2020-May-19 15:49:25 . . . . Segger_read_debug_port_register: JLink INFO JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
      2020-May-19 15:49:25 . . . . Segger_read_debug_port_register: JLink INFO T1D70 000:200.497
      2020-May-19 15:49:25 . . . . Segger_read_debug_port_register: JLink INFO failed
      2020-May-19 15:49:25 . . . . Segger_read_debug_port_register: JLink INFO T1D70 000:204.119
      2020-May-19 15:49:25 . . . . Segger_read_debug_port_register: JLink INFO - 9.649ms returns -1
      2020-May-19 15:49:25 . . . . Segger_read_debug_port_register: JLinkARM.dll reported "-1", an unknown error.
      2020-May-19 15:49:25 . . . . . Segger_abort_debug_action
      2020-May-19 15:49:25 . . . . . Segger_abort_debug_action: Attempting to clear any configuration errors in debug port before closing connection.
      2020-May-19 15:49:25 . . . . . Segger_abort_debug_action: JLink INFO T1D70 000:213.487
      2020-May-19 15:49:25 . . . . . Segger_abort_debug_action: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
      2020-May-19 15:49:25 . . . . . Segger_abort_debug_action: JLink INFO T1D70 000:217.688
      2020-May-19 15:49:25 . . . . . Segger_abort_debug_action: JLink INFO - 5.965ms returns -1
      2020-May-19 15:49:25 . . . . . Segger_abort_debug_action: JLinkARM.dll reported "-1", an unknown error.
      2020-May-19 15:49:25 . . . Segger_read_debug_port_register: JLink INFO T1D70 000:223.024
      2020-May-19 15:49:25 . . . Segger_read_debug_port_register: JLink INFO JLINK_Unlock()
      2020-May-19 15:49:25 nRF_close_dll
      2020-May-19 15:49:25 . nRF52_close_dll
      2020-May-19 15:49:25 . . Segger_close
      2020-May-19 15:49:25 . . . Segger_disconnect_from_emu
      2020-May-19 15:49:25 . . . . Segger_is_connected_to_emu: JLink INFO T1D70 000:235.488
      2020-May-19 15:49:25 . . . . Segger_is_connected_to_emu: JLink INFO T1D70 000:239.125
      2020-May-19 15:49:25 . . . . Segger_is_connected_to_emu: JLink INFO - 5.379ms returns 0x01
      2020-May-19 15:49:25 . . . . Segger_disconnect_from_emu
      2020-May-19 15:49:25 . . . . . Segger_is_connected_to_device
      2020-May-19 15:49:25 . . . . . Segger_is_connected_to_device: JLink INFO T1D70 000:246.224
      2020-May-19 15:49:25 . . . . . Segger_is_connected_to_device: JLink INFO JLINK_IsConnected()
      2020-May-19 15:49:25 . . . . . Segger_is_connected_to_device: JLink INFO T1D70 000:249.057
      2020-May-19 15:49:25 . . . . . Segger_is_connected_to_device: JLink INFO - 4.126ms returns FALSE
      2020-May-19 15:49:25 . . . . . Segger_is_debug_region_powered
      2020-May-19 15:49:25 . . . . . . Segger_read_debug_port_register
      2020-May-19 15:49:25 . . . . . . . Segger_is_connected_to_emu
      2020-May-19 15:49:25 . . . . . . . Segger_is_connected_to_emu: JLink INFO T1D70 000:254.551
      2020-May-19 15:49:25 . . . . . . . Segger_is_connected_to_emu: JLink INFO JLINK_IsOpen()
      2020-May-19 15:49:25 . . . . . . . Segger_is_connected_to_emu: JLink INFO T1D70 000:256.369
      2020-May-19 15:49:25 . . . . . . . Segger_is_connected_to_emu: JLink INFO - 2.731ms returns 0x01
      2020-May-19 15:49:25 . . . . . . Segger_read_debug_port_register: JLink INFO T1D70 000:258.206
      2020-May-19 15:49:25 . . . . . . Segger_read_debug_port_register: JLink INFO JLINK_Lock()
      2020-May-19 15:49:25 . . . . . . . Segger_write_debug_port_register
      2020-May-19 15:49:25 . . . . . . . Segger_write_debug_port_register: JLink INFO T1D70 000:261.083
      2020-May-19 15:49:25 . . . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
      2020-May-19 15:49:25 . . . . . . . Segger_write_debug_port_register: JLink INFO T1D70 000:263.383
      2020-May-19 15:49:25 . . . . . . . Segger_write_debug_port_register: JLink INFO - 3.050ms returns -1
      2020-May-19 15:49:25 . . . . . . . Segger_write_debug_port_register: JLinkARM.dll reported "-1", an unknown error.
      2020-May-19 15:49:25 . . . . . . . . Segger_abort_debug_action
      2020-May-19 15:49:25 . . . . . . . . Segger_abort_debug_action: Attempting to clear any configuration errors in debug port before closing connection.
      2020-May-19 15:49:25 . . . . . . . . Segger_abort_debug_action: JLink INFO T1D70 000:267.125
      2020-May-19 15:49:25 . . . . . . . . Segger_abort_debug_action: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
      2020-May-19 15:49:25 . . . . . . . . Segger_abort_debug_action: JLink INFO T1D70 000:268.942
      2020-May-19 15:49:25 . . . . . . . . Segger_abort_debug_action: JLink INFO - 2.433ms returns -1
      2020-May-19 15:49:25 . . . . . . . . Segger_abort_debug_action: JLinkARM.dll reported "-1", an unknown error.
      2020-May-19 15:49:25 . . . . . . Segger_read_debug_port_register: JLink INFO T1D70 000:270.802
      2020-May-19 15:49:25 . . . . . . Segger_read_debug_port_register: JLink INFO JLINK_Unlock()
      2020-May-19 15:49:25 . . . . Segger_disconnect_from_emu: JLink INFO T1D70 000:285.184
      2020-May-19 15:49:25 . . . . Segger_disconnect_from_emu: JLink INFO JLINK_Close()
      2020-May-19 15:49:25 . . Segger_close: Freeing Library.
      2020-May-19 15:49:25 nRF_close_dll: Freeing Library.
      Thanks for your help
