J-Link Commander Renesas RX Authentication Key Invalid- Erase chip after n attempts
    • J-Link Commander Renesas RX Authentication Key Invalid- Erase chip after n attempts
      SEGGER J-Link Commander V6.46k (Compiled Jul 22 2019 10:50:35)
      DLL version V6.46k, compiled Jul 22 2019 10:50:24
      I have some boards with a RX231 Renesas on it that used a while back, put the protection by code back then but can't remember what it was so I keep getting the "Debugger authentication failed. Authentication key rejected by CPU"
      Is there a way to setup JLink to erase a chip after Debugger authentication failed for a certain number of attempts (similar to what the E1 Renesas programmer does)?
      Thanks.
    • New
      This is currently not supported as it also involves switching from JTAG/FINE to the UART boot mode of the device and most customers do not have all required pins for this connected.
      Also, unfortunately, the connection for UART boot mode may use different pins than JTAG/FINE on some devices, which makes things even more problematic as some of the pins may not be available on the current RX adapters we offer.
      I have put this onto the internal ToDo list but without any schedule so far.
