[SOLVED] Do we have support with J-LINK EDU for CORTEX-A53 AARCH32 mode?
  • [SOLVED] Do we have support with J-LINK EDU for CORTEX-A53 AARCH32 mode?
    All,
    I have a try with J-LINK EDU for cortex-A53 AARCH32 mode. But after the core is identified, the halt command failed. The target is on FPGA, so the coe run on 10MHz clock only. We have successfully debug the core with TRACE32 for quite a few months. So I think the core should be fine. See below logs
    J-Link>connect
    Please specify device / core. <Default>: CORTEX-A53
    Type '?' for selection dialog
    Device>?
    J) JTAG (Default)
    S) SWD
    T) cJTAG
    TIF>J
    Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
    JTAGConf>
    Speed>
    Device "CORTEX-A53" selected.
    Connecting to target via JTAG
    TotalIRLen = 4, IRPrint = 0x01
    JTAG chain detection found 1 devices:
    #0 Id: 0x6BA00477, IRLen: 04, CoreSight JTAG-DP
    Scanning AP map
    AP scan stopped (required AP found)
    AP[0]: APB-AP
    Scanning ROMTbl @ 0x80000000
    [0]Comp[0] @ 0x80400000: ROM Table
    Scanning ROMTbl @ 0x80400000
    [1]Comp[0] @ 0x80410000: Cortex-A53
    [1]Comp[1] @ 0x80420000: CTI-A53
    Core found. Stopped ROM table scan: wiki.segger.com/ROMTableScan
    Cortex-A53 @ 0x80410000 (detected)
    CoreCTI @ 0x80420000 (detected)
    Debug architecture: ARMv8
    6 code breakpoints, 4 data breakpoints
    Add. info (CPU temp. halted)
    Cache info:
    Inner cache boundary: none
    LoU Uniprocessor: 0
    LoC: 0
    LoU Inner Shareable: 0
    Exception AArch usage: All: AArch32
    VMSAv8-64: Supports 48-bit VAs
    Cortex-A53 identified.
    J-Link>h
    WARNING: CPU could not be halted
    /Li.
  • Hello Li,
    Yes the A53 architecture is supported on J-Link EDU V10 or later:
    segger.com/products/debug-prob…nk/models/model-overview/
    However as the generic connect to A53 platforms rarely works you most likely need to do target specific initialization steps. You can do so using our JLinkScript interface. For more information see the J-Link user manual.
    We see that you are using a TRACE32 probe in your setup so we are not exactly sure how a J-Link EDU fits into that setup. Please note that any commercial use of the J-Link EDU is prohibited and is a license violation.
    For commercial usage at least a J-Link Base is required.
    The J-Link EDU is *not* a probe for evaluation of commercial setups. For more information about the license conditions see here:
    segger.com/products/debug-probes/j-link/models/j-link-edu/
