sawtooth issue
    • sawtooth issue
      I am new for emwin. My platform is RT1052, I encounter an issue when using GUI_DrawCircle and GUI_DrawLine, Attached is the pic, sawtooth can be seen. It is normal when I display string or rect, and also display Widgets very well. What kind of problem can cause this kind of issue? I supposed the problem is likely to be in the hardware driver, but I do not know how to address it. Thanks a lot for your support.
      Following is the code.
      void MainTask(void)
      GUI_Init();
      WM_MULTIBUF_Enable(1);
      GUI_SetBkColor(GUI_BLUE);
      GUI_Clear();
      GUI_SetPenSize(10);
      GUI_FillCircle (100, 60, 50);
      GUI_DrawCircle (250, 100, 50);
      GUI_DrawLine(200,200,300,350);
      GUI_DrawLine(400,200,200,350);
      GUI_FillRect(100,400,300,450);
      GUI_SetFont(GUI_FONT_32_1);
      GUI_DispStringHCenterAt("ABCDEFG", 100, 320);
      while (1);
      this is probably a cache problem. The attached LCDConf.c should fix your problem. The relevant function calls that clear the cache are SCB_CleanInvalidateDCache() and GUI_DCACHE_SetClearCacheHook(_ClearCache).
      Also, note that WM_MULTIBUF_Enable() only enables automatic multi-buffering when using the Window Manager. For 2D graphic operations (such as drawing circles etc.) GUI_MULTIBUF_Begin() and GUI_MULTIBUF_End() have to be used to switch between the buffers.
      Florian
      • LCDConf.zip
        (4.36 kB, downloaded 84 times, last: )
    • Hi, Florian
      Thanks a lot for your fast response. This issue can be solved by 2 method. your reminder about GUI_MULTIBUF_Begin() use is really help. Could you please help to explain why the following ways can work?
      The first solution is add GUI_MULTIBUF_Begin() and GUI_MULTIBUF_End();
      void MainTask(void)
      GUI_Init();
      GUI_Clear();
      GUI_MULTIBUF_Begin();
      GUI_SetPenSize(10);
      GUI_MULTIBUF_End();
      while (1);
      The second methold is add GUI_Exec() in the while loop;
      void MainTask(void)
      GUI_Init();
      GUI_Clear();
      GUI_SetPenSize(10);
      while (1){
      GUI_Exec();
