[SOLVED] IRQ not getting executed in Segger Embedded Studio for ARM V3.4
  • [SOLVED] IRQ not getting executed in Segger Embedded Studio for ARM V3.4
    I am using Seggar Embedded Studio for ARM V3.4 and nRF_SDK 12.3.0.
    I am trying to understand interrupts and interrupt handlers.
    The interrupt request for Watchdog timer (i.e. void WDT_IRQHandler(void)) is not getting executed. The control is not going to WDT_IRQHandler.
    I made the following attempts to verify if control was going to the WDT_IRQHandler():-
    1>I tried to switch on the LED
    2>I tried to switch off the LED
    3>Only a printf() statement inside WDT_IRQHandler() (in debug mode)
    The above attempts did not work
    I have defined the following preprocessor definitions:-
    NO_VTOR_CONFIG
    BLE_STACK_SUPPORT_REQD
    NRF51422
    BOARDS_PCA10028
    SWI_DISABLE0
    NRF51
    Please let me know if there is some other configuration that is required to be done in seggar. I have attached the main.c and SDK_Config.h files as txt files
    main_txt.txt
    sdk_config_txt.txt
    For target specific and Nordic SDK specific questions we recommend contacting the silicon vendor directly.
