PTP Client and Webserver Initialization Question
  • PTP Client and Webserver Initialization Question
    I am currently evaluating the Embedded Studio Pro Cortex-M ide, libraries and the PTP Client. I have had good success working with the PTP Client by itself. Today I tried adding a Webserver task and was unable to get the Webserver to respond until I moved the PTP Task start code from here:
    1. IP_Init();
    2. IP_AddLogFilter(IP_MTYPE_APPLICATION);
    3. _IFaceId = IP_INFO_GetNumInterfaces() - 1; // Get the last registered interface ID as this is most likely the interface we want to use in this sample.
    4. OS_SetPriority(OS_GetTaskID(), TASK_PRIO_IP_TASK); // For now, this task has highest prio except IP management tasks.
    5. OS_CREATETASK(&_IPTCB , "IP_Task" , IP_Task , TASK_PRIO_IP_TASK , _IPStack); // Start the TCP/IP_Task.
    6. #if USE_RX_TASK
    7. OS_CREATETASK(&_IPRxTCB , "IP_RxTask" , IP_RxTask , TASK_PRIO_IP_RX_TASK, _IPRxStack); // Start the IP_RxTask, optional.
    8. #endif
    9. OS_CREATETASK(&_PTPcTCB, "PTPClient", _PTPcTask, TASK_PRIO_IP_PTPC , _PTPcStack); // Start the PTP client.
    10. IP_AddStateChangeHook(&_StateChangeHook, _OnStateChange); // Register hook to be notified on disconnects.
    11. IP_Connect(_IFaceId); // Connect the interface if necessary.
    12. OS_SetPriority(OS_GetTaskID(), 255); // Now this task has highest prio for real-time application. This is only allowed when this task does not use blocking IP API after this point.
    13. while (IP_IFaceIsReadyEx(_IFaceId) == 0) {
    14. OS_Delay(50);
    15. BSP_ToggleLED(1);
    16. }
    17. //
    18. // Start Webserver
    19. //
    20. OS_CREATETASK(&_WEBServer_TCB, "Webserver", WebserverTask, TASK_PRIO_WEBS_PARENT, _WEBServer_Stack);
    to Here (below). Is this acceptable? Are there any consequences with starting the PTP Client later in the IP/Ethernet setup process?
    1. IP_Init();
    6. #if USE_RX_TASK
    8. #endif
    9. IP_AddStateChangeHook(&_StateChangeHook, _OnStateChange); // Register hook to be notified on disconnects.
    10. IP_Connect(_IFaceId); // Connect the interface if necessary.
    11. OS_SetPriority(OS_GetTaskID(), 255); // Now this task has highest prio for real-time application. This is only allowed when this task does not use blocking IP API after this point.
    12. while (IP_IFaceIsReadyEx(_IFaceId) == 0) {
    13. OS_Delay(50);
    14. BSP_ToggleLED(1);
    15. }
    16. OS_CREATETASK(&_PTPcTCB, "PTPClient", _PTPcTask, TASK_PRIO_IP_PTPC , _PTPcStack); // Start the PTP client.
    17. //
    19. //
  • Hello Jim,
    Sorry about the late reply.
    I assume that your first combination of samples did not work has to do with the following line:
    This is basically only meant to set the current task to its highest prio possible if there is nothing more to do aka only short checking of the link state
    and maybe LED toggling.
    Without seeing the complete setup I assume you ended up with some kind of prio deadlock in your application setup.
    Basically it should be fine to combine the samples AFTER the link up check. The general rule should always be that
    a client (the end that sends on its own) should only start or be activated if link is up. However we typically have multiple
    checks in samples and or the stack to make sure this should not result in a problem.
    For any server end this is typically not important and you can start it wherever you want. If link is not up no client will
    be able to connect to the server anyhow.
    Oliver
