Widget ID definitions in different windows
    • Widget ID definitions in different windows
      I have two different windows.
      Window1 widget ids
      #define GUI_ID_WINDOW_0 (GUI_ID_USER + 0x00)
      #define GUI_ID_ICONVIEW0 (GUI_ID_USER + 0x01)
      #define GUI_ID_ICONVIEW1 (GUI_ID_USER + 0x02)
      Window2 widget ids
      each window has a resource table which is used to create the widgets by using GUI_CreateDialogBox()
      My question is can two windows have same widget id's?
      On Window1 widget iconview1 released event i have deleted the current window by using WM_DeleteWindow()
      and created the window2 using GUI_CreateDialogBox()
      I get the following emwin error.
      When i modify the GUI ID's as below the error does not come.
      I have kept different ids for iconview widget in both windows.
      Window1 widget ids
      Window2 widget ids
      #define GUI_ID_ICONVIEW0 (GUI_ID_USER + 0x03)
      #define GUI_ID_ICONVIEW1 (GUI_ID_USER + 0x04)
      So if GUI id's for Iconview widget are same i get the error as above and if GUI id's are different i don't get any error.
      I get this error for iconview widgets only.
      My question is why the error is coming?
      What is the standard way of defining id's if 2 windows are used, each window with 2 iconview widgets?
      Anuj
      all of the IDs of windows (and therefore widgets as well) have to be unique or else the creation of that window/widget will fail. To be on the safe side, use unique IDs for all windows and widgets.
      Florian
