[SOLVED] Problem to erase a protected Infineon-ARM M4
  • [SOLVED] Problem to erase a protected Infineon-ARM M4
    Hi.
    On a Infineon XMC4700 Arm processor, i've activate the sector read/write protection with a password -> XMC_FLASH_InstallProtection(0, PROTECT_RP_WPS0, (uint32_t)PW1, (uint32_t)PW2);
    Now I have no way to erase the whole chip.
    The connection with JLink is ok, but if i try to unlock the device, JLink show's a error.
    is there a way to delete the chip if i know the passwords?
    Here the output from JLink:
    J-Link>connect
    Device "XMC4700-1536" selected.
    Connecting to target via SWD
    Performing XMC4500 connection sequence.
    AP map detection skipped. Manually configured AP map found.
    AP[0]: AHB-AP (IDR: Not set)
    AP[0]: Core found
    CoreSight components:
    ROMTbl[0] @ E00FF000
    ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
    ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
    Cortex-M4 identified.
    J-Link>unlock Kinetis
    Found SWD-DP with ID 0x2BA01477
    Unlocking device...ERROR: Read from DP/AP register failed!
    J-Link>erase
    Erasing device (XMC4700-1536)...
    WARNING: CPU could not be halted
    ****** Error: Can not read register 16 (XPSR) while CPU is running
    Can not read register 20 (CFBP) while CPU is running
    Can not read register 0 (R0) while CPU is running
    Can not read register 1 (R1) while CPU is running
    Can not read register 2 (R2) while CPU is running
    Can not read register 3 (R3) while CPU is running
    Can not read register 4 (R4) while CPU is running
    Can not read register 5 (R5) while CPU is running
    Can not read register 6 (R6) while CPU is running
    Can not read register 7 (R7) while CPU is running
    Can not read register 8 (R8) while CPU is running
    Can not read register 9 (R9) while CPU is running
    Can not read register 10 (R10) while CPU is running
    Can not read register 11 (R11) while CPU is running
    Can not read register 12 (R12) while CPU is running
    Can not read register 14 (R14) while CPU is running
    Can not read register 15 (R15) while CPU is running
    Can not read register 17 (MSP) while CPU is running
    Can not read register 18 (PSP) while CPU is running
    ****** Error: Failed to prepare for programming.
    Could not preserve target memory.
    ERROR: Erase returned with error code -1.
    If you locked your device with a password, there is no way for the J-Link to unlock your device without it.
    You will have to unlock the device manually (e.g. via the J-Link Commander).
    The necessary registers should be writable after connecting to the device.
    For all necessary commands (e.g. w4) please refer to the following article:
    wiki.segger.com/J-Link_Commander#Commands
    Does this resolve the problem?
