Drawing a transparent child window above the parent which has a GUI_PNG_Draw in WM_Paint results in inconsistent UI
    • Drawing a transparent child window above the parent which has a GUI_PNG_Draw in WM_Paint results in inconsistent UI
      First created a window : parentWindow.(0, 0, 480, 272)
      In this parentWindow's WM_PAINT: Using GUI_PNG_Draw posted a background image to the complete window
      In parentWindows's WM_CREATE: created a child window: childWindow with window Flags WM_CF_HASTRANS | WM_CF_SHOW (140, 11, 100, 250)
      In child window's WM_PAINT used GUI_AA_DrawArc to draw an arc every second (also used WM_TIMER)
      The child window is transparent but the behavior is becoming inconsistent after few seconds...
      Please help
      Thank you Florian, the mistake I was doing is setting the parent window to WM_CF_TRANS and not the child.
      But now I'm facing one more issue:
      When I try to display any text in childWindow using GUI_SetTextMode(GUI_TM_TRANS)... it starts overlapping.
      If I use GUI_Clear(), then it is repainting the child window with black color and transparency is lost
      it is overlapping, because the background isn't redrawn. The parent window is missing a WM_PAINT case in _cbParent() that cleares the window.
      1. case WM_PAINT:
      2. GUI_SetBkColor(GUI_BLACK);
      3. GUI_Clear();
      4. break;
      Florian
      But if it clear the parent window now, the image will be covered by this black parent window.
      Also, if I draw the png image again in WM_PAINT of parent window after GUI_Clear, won't it be memory intensive??
      that is correct, but since the parent window does not have the WM_CF_HASTRANS flag, it will cover the image displayed in the main window anyway.
      Instead of adding the WM_PAINT case to _cbParent(), changing the window flags to WM_CF_SHOW | WM_CF_HASTRANS should fix the problem.
      1. hParent = WM_CreateWindowAsChild(8, 11, 464, 250, pMsg->hWin, WM_CF_SHOW | WM_CF_HASTRANS, _cbParent, 0);
      Although, currently the parent window has no use except creating the child window. You could just directly create the child window as a child of the main window and have the same result, but a simpler window structure.
      Florian
