[SOLVED] Problem with restoring original FW on embOS/IP switch board
  • [SOLVED] Problem with restoring original FW on embOS/IP switch board
    Dear community,
    I'm trying to restore the original FW on embOS/IP switch board.
    OS: Debian 10.3 / Windows 10
    PCB: V2.0A
    I'm following instructions from ReadMe.txt
    (segger.com/downloads/eval/Segg…rd_CortexM_EmbeddedStudio)
    Segger-embOS-SW/Prebuild$ /opt/SEGGER/JLink_V670/JLinkExe -device MK66FN2M0XXX18 -speed 4000 -CommanderScript CommandFile.jlink
    SEGGER J-Link Commander V6.70 (Compiled Mar 27 2020 14:37:00)
    DLL version V6.70, compiled Mar 27 2020 14:36:47
    J-Link Command File read successfully.
    Processing script file...
    J-Link connection not established yet but required for command.
    Firmware: J-Link OB-STM32F072-CortexM compiled Jan 7 2019 14:09:37
    Hardware version: V1.00
    S/N: 678000124
    VTref=3.300V
    Selecting SWD as current target interface.
    Target connection not established yet but required for command.
    Device "MK66FN2M0XXX18" selected.
    Connecting to target via SWD
    InitTarget()
    Unknown DP version. Assuming DPv0
    AP[2]: Stopped AP scan as end of AP map has been reached
    AP[1]: JTAG-AP (IDR: 0x001C0000)
    AP[0]: Core found
    CoreSight components:
    ROMTbl[0] @ E00FF000
    ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
    ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
    ROMTbl[0][6]: E0042000, CID: B105900D, PID: 003BB907 ETB
    ROMTbl[0][7]: E0043000, CID: B105900D, PID: 001BB908 CSTF
    Cortex-M4 identified.
    Halting CPU for downloading file.
    Downloading file [embOS_IP_Switchboard_K66.bin]...
    ****** Error: Timeout while preparing target, RAMCode did not respond in time. (PC = 0x00000000, CPSR = 0x20001943, LR = 0x21000005)!
    Failed to prepare RAMCode using RAM
    Unspecified error -1
    Reset delay: 0 ms
    AfterResetTarget()
    Script processing completed.
    I'm using the newest J-Link driver/utility
    The same issue is observed on Windows (also with using the newest possible for downloading J-Link drivers - V6.70b
    I did not modified the FW in J-Link OB (I'm using the FW provided with the board).
    Changing -speed to 1000 doesn't help. Please also find the log file attached.
    Could somebody help me with restoring the original FW?
    Thanks in advance for help.
    Since your J-Link is still in support period, could you please open a support ticket for this issue?
    Please find all required information in my signature below this message.
    This thread will be closed now to avoid multiple information streams.
