[SOLVED] Using #define value as parameter to printf
  • [SOLVED] Using #define value as parameter to printf
    I would like to print define value using printf, for example:
    #define MODULE_NAME MODULE1
    printf (MODULE_NAME);
    Is there any way to do so without adding commas to the test ("MODULE1")?
    eyal.
  • By "commas" you mean "quotes" ?
    Remember that the preprocessor just does a simple text substitution
    So, for this to work, your #define must expand to something that would be valid as a printf argument.
    So, if you want MODULE_NAME to expand to a string, you will have to define it as such; eg,
    #define MODULE_NAME "MODULE1"
    Then you can put MODULE_NAME anywhere that a string literal would be legal.
    Note that this is standard 'C' stuff - nothing specific to Segger or SES
