[SOLVED] J-Trace CM via USB-Hub
  • [SOLVED] J-Trace CM via USB-Hub
    I have a J-Trace CM (S/N: 203200738) and when it’s connect directly to my laptop (Thinkpad T590 with Windows 10) the device is useable (Power-Led and USB-Led steady green) [directly-connected.png]
    But when I connect via an USB-Hub (e.g. Aukey USB C Hub Ultra Slim USB C Adapter) the device is not useable (Power-Led steady green and USB-Led flashing green) [usb-hub.png, not-directly-connected.png]
    Additionally it’s also not possible to update the driver [no-driver-update.png]
    Is there a workaround for this? Can I use the J-Trace via an USB Hub at all? Can you recommend an USB Hub?
    Thanks for the help.
    Yes, the J-Trace works when connected to a hub.
    We also do not recommend a particular hub, as essentially all hubs have some kind of downside.
    So it depends on what suits you the most.
    Therefore we recommend working without a hub for this reason, wherever possible.
    You will have to choose a hub which is able to supply the J-Trace with enough power to work.
    The J-Trace CM can draw up to 400 mA.
    Looking at the specification of the hub you are using shows that it can supply a maximum of 0,9A, which is split to all slots:
    shop.aukey.com/collections/auk…4-port-usb-3-0-type-c-hub
    Unfortunately, 225 mA is definitively not enough power.
    In general:
    If you cannot go without a hub, it is recommended to use an externally powered one, since it usually provides more power.
    To be sure, please check the datasheet of the corresponding USB hub (ideally on the manufacturers page).
    Do you have any further questions?
  • Hi Toba,
    Since you do not have any further, related questions, we will consider this thread as closed now.
