[SOLVED] Ozone: program SDRAM at debug startup
  • [SOLVED] Ozone: program SDRAM at debug startup
    I have a board with LPC1785 MCU and an external SDRAM. At MCU reset the SDRAM isn't configured so it isn't mapped to the system memory.
    I'd like to know if Ozone can be configured to program internal Flash memory and external SDRAM at debug startup. Data to program to SDRAM are at a specific address in the elf file.
    For SDRAM inits we recommend using a JLinkScript. The JLinkScript API is explained in the J-Link user manual UM08001.
    How to use a JLinkScript in Ozone is explained here:
    wiki.segger.com/J-Link_script_files#Ozone
    After SDRAM is initialized you can use the normal Ozone debug setup to program both Flash and SDRAM. Just make sure that the application you are programming utilizes both memory areas.
    Do you mean, use JLINK_MEM_WriteUxx() functions in the script to program registers of MCU such way SDRAM is initialized?
    I think Ozone normally program only internal Flash memory of selected MCU. How to instruct Ozone to transfer data in a specific memory area (start address-end address)?
    Correct.
    Ozone gives a write command to J-Link. What kind of memory it is it does not care. As long as it is part of your application it will be written.
    What type of memory it is J-Link will automatically take care of.
