I'm using HEW to target code for the Renesas RX platform. I started a C++ project from scratch and, I think, set up most of the build environment correctly. I realize that my question is more of a tools question than an OS question, but I think this forum is the place where I'm likely to get the best answer.
I've reduced the compile/link errors I'm getting to two:
Phase Linker starting
C:\Code\OS\Segger_embOS\GNURX\LIB\libosLDP.a(OS_StackInfo.o): In function `OS_GetSysStackBase':
(.text+0x2): undefined reference to `ram_start'
C:\Code\OS\Segger_embOS\GNURX\LIB\libosLDP.a(OS_StackInfo.o): In function `OS_GetSysStackSize':
(.text+0xf): undefined reference to `ram_start'
Phase Linker finished
In a project targeting the RX platform, and using the GNU RX toolchain, where is ram_start defined?
I have a second project; it's the same code but targets the HEW compiler. Though I believe my build environments between the two projects are the same, there's still something wrong. When I compile my HEW project, the linker gives me:
L2310 (E) Undefined external symbol "_OS_CreateTaskEx_R" referenced in "C:\Code\MyProject_HEWRX\Debug\debugtask.obj"
L2310 (E) Undefined external symbol "_OS_CreateTaskEx_R" referenced in "C:\Code\MyProject_HEWRX\Debug\guitask.obj"
What did I fail to include in my build environment that is causing this linker error?
As a newcomer to embOS, and even to C programming in an embedded environment, I appreciate any help the community can offer.
