Dear all,
I wanted to automate programming of my microcontroller nRF52832 with j-link BASE Compact using Command Line Interface (JLink.exe), calling the script from LabVIEW. I have to automate some operations, currently done with nRFgo Studio:
- selection of "nRF5x Programming"
- selection of a file to program in region "Program SoftDevice", click on "Program" then "Verify"
- selection of a file to program in region "Program Application", click on "Program" then "Verify"
First, I'm testing the commands from Command Prompt And I've some difficulties... This is what I've done (in Bold, commands I've typed):
Microsoft Windows [version 10.0.18362.476]
(c) 2019 Microsoft Corporation. Tous droits réservés.
C:\Users\fmi>"C:\Program Files (x86)\SEGGER\JLink\JLink.exe"
SEGGER J-Link Commander V6.62d (Compiled Mar 2 2020 09:23:14)
DLL version V6.62d, compiled Mar 2 2020 09:22:41
Firmware: J-Link V10 compiled Jan 7 2020 16:51:47
Hardware version: V10.10
S/N: 820102851
License(s): GDB
VTref=3.290V
J-Link>Device NRF52832_XXAA
J-Link>connect
Please specify target interface:
J) JTAG (Default)
S) SWD
T) cJTAG
TIF>SWD
Specify target interface speed [kHz]. <Default>: 4000 kHz
Speed>
Device "NRF52832_XXAA" selected.
Connecting to target via SWD
InitTarget() start
InitTarget() end
Found SW-DP with ID 0x2BA01477
DPIDR: 0x2BA01477
AP[2]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x24770011)
AP[1]: JTAG-AP (IDR: 0x02880000)
AP[0]: Core found
Found Cortex-M4 r0p1, Little endian.
CoreSight components:
ROMTbl[0] @ E00FF000
ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
Cortex-M4 identified.
J-Link>erase
Erasing device...
J-Link: Flash download: Total time needed: 0.396s (Prepare: 0.251s, Compare: 0.000s, Erase: 0.142s, Program: 0.000s, Verify: 0.000s, Restore: 0.003s)
Erasing done.
J-Link>loadfile C:\AppSBZ\Sources\SoftDevice_s132.hex
Downloading file [C:\AppSBZ\Sources\SoftDevice_s132.hex]...
J-Link: Flash download: Bank 0 @ 0x00000000: 1 range affected (126976 bytes)
J-Link: Flash download: Total time needed: 2.287s (Prepare: 0.037s, Compare: 0.029s, Erase: 0.000s, Program: 2.193s, Verify: 0.003s, Restore: 0.023s)
O.K.
J-Link>loadfile C:\AppSBZ\Sources\nrf52832_02122019.hex
Downloading file [C:\AppSBZ\Sources\nrf52832_02122019.hex]...
J-Link: Flash download: Bank 0 @ 0x00000000: 1 range affected (57344 bytes)
J-Link: Flash download: Total time needed: 1.081s (Prepare: 0.030s, Compare: 0.020s, Erase: 0.000s, Program: 1.009s, Verify: 0.003s, Restore: 0.016s)
O.K.?
When loading, a windows appears with a pogression bar.
- how to send the command "Verify"?
- how to make the difference under flashing Program SoftDevice and Program Application? I'm not sure, but maybe the second load crushes the first one...
Finally, I've tried to create a file "script.jlink" with those commands:
erase
r
I wanted to call it like this:
"C:\Program Files (x86)\SEGGER\JLink\JLink.exe" -Device NRF52832_XXAA -if SWD -speed 4000 -CommanderScript C:\AppSBZ\Sources\script.jlink
But I definitively doesn't work, I don't understand why...
I work with a Windows 10 Enterprise Computer (version 1903), a programmer j-link BASE Compact (Version 10.10, Date 19-44, Part 8.19.00, S/N: 820102851), SEGGER J-Link Commander V6.62d, Firmware J-Link V10 and nRFgo Studio 1.21.2.10
Is it possible to help me to find a way to solve my problems? Thank you per advance!
Francis Millerot
S/N: 820102851
License(s): GDB
VTref=3.290V
J-Link>connect
J) JTAG (Default)
S) SWD
T) cJTAG
TIF>SWD
Speed>
InitTarget() start
InitTarget() end
DPIDR: 0x2BA01477
AP[0]: Core found
J-Link>erase
Erasing device...
Erasing done.
O.K.
O.K.?
erase
r
Francis Millerot
