Hi SEGGER team,
I'm using uVision environment to develope simple application on LPC2148. I've started with really simple code to see how debugging works in uVision. Unfortunately, whenever I'm tring to go debug mode I got this error:
***JLink Warning: PC of target system has unexpected value of 0x40000000 after reset.
Can you tell me when this bug occur? How to fix this? Where make the change?
I've already tried adices from comment 5 in this thread:
LPC3250 J-Link Error
but it didn't change anything.
Full console output from uVision:
Device = LPC2148
Info: Device "LPC2148" selected.
VTarget = 3.272V
Info: JTAG chain detection found 1 devices:
Info: #0 Id: 0x4F1F0F0F, IRLen: 04, ARM7TDMI-S Core
Info: Auto JTAG speed: 1000 kHz
Info: Core does not stop after Reset, setting WP to stop it.
DLL version V6.62c, compiled Feb 21 2020 17:43:19
Firmware: J-Link EDU Mini V1 compiled Jan 7 2020 16:53:19
Hardware: V1.00
Hardware-Breakpoints: 2
Software-Breakpoints: 8192
Watchpoints: 0
Id of device #0: 0x4F1F0F0F
ARM7 identified.
JTAG speed: 100 kHz
Full Chip Erase Done.
Programming Done.
Verify OK.
JTAG speed: 100 kHz
Application running ...
Flash Load finished at 23:38:22
Device = LPC2148
VTarget = 3.272V
Hardware: V1.00
Watchpoints: 0
ARM7 identified.
JTAG speed: 100 kHz
Programming Done.
Verify OK.
JTAG speed: 100 kHz
