[SOLVED] Problems with establishing connection to target.
  • [SOLVED] Problems with establishing connection to target.
    Hello Everyone,
    After flashing a program that went to Fault ISR, I no longer can connect to the board I have.
    I get flashing Red Light on the probe and you may find the log files attached.
    I am not too familiar with this probe so I am not sure why I can't connect.
    I used J-Flash and Innate tools from Code Composer Studio and behaviour seems to be the same.
    Best Regards,
    Tuna Bicim
    • Log.log
      (1.88 kB, downloaded 515 times, last: )
    • Log2.log
      (307 Byte, downloaded 495 times, last: )
  • I don't know what "red LED" means on your probe (I have different probe - JTrace where red is trace), but I'd first check the wiring and then try OpenOCD, like this:
    1. openocd -f interface/jlink.cfg -c "transport select hla_swd" -c "gdb_memory_map disable" -f target/stm32f0x.cfg
    I'm just guessing what MCU you have (guesses STM32F0x) and guessing SWD connection, the selection Cortex-M0 doesn't tell which MCU you have exactly.
    If OpenOCD can connect, you are good. You can add extra -d parameter for more verbose output.
  • Hi Tuna,
    Could you please tell us which device exactly you are using?
    How to flash and how to exactly connect to a device often highly depends on the device specifics.
    Does it work when you pass the correct device name to J-Flash / Code Composer Studio?
  • Hello Fabian,
    My device is a TM4C123FH6PM connected through JTAG. I tried both J-Flash/J-Link Commander and Code Composer Studio. I think the JTAG pins are locked.
    I tried the unlock procedure mentioned on TI forums from the J-Link Commander and I also jumped pins from a EK-TM4C123 board using the ICDI JTAG connection they provide.
    Both solutions didn't work.
    I think I will replace the chip to continue forward.
    Best,
    Tuna Bicim
  • Hi Tuna,
    As long as this option is no problem for you.
    We will consider this thread as closed.
