[SOLVED] Nucleo-F303RE - CPU could not be halted
  • [SOLVED] Nucleo-F303RE - CPU could not be halted
    I am using STM32 Nucleo-F446RE board to program and debug a custom STM32F3 board through J-Link and it works fine. To be able to debug the communication between 2 of my custom boards I wanted to debug them both simultaneously, so I bought a second Nucleo board, this time STM32 Nucleo-F303RE. However I can't make the new Nucleo flash and debug my microcontroller.
    I used the Reflash Utility to convert the ST-Link into J-link. I tested it and it didn't work, so I updated the firmware, but no result.
    I use the exactly same setup with both Nucleos: same target board, same cables, same jumper configuration. I use Eclipse IDE as a programming environment. Here are both SEGGER logs (working and not working) that I get:
    SEGGER Log for Nucleo-F446RE (working):
    Brainfuck Source Code
    1. SEGGER J-Link GDB Server V6.60f Command Line Version
    2. JLinkARM.dll V6.60f (DLL compiled Jan 20 2020 16:15:17)
    3. Command line: -if swd -device STM32F303CB -endian little -speed 1000 -port 2331 -swoport 2332 -telnetport 2333 -vd -ir -localhostonly 1 -singlerun -strict -timeout 0 -nogui
    4. -----GDB Server start settings-----
    5. GDBInit file: none
    6. GDB Server Listening port: 2331
    7. SWO raw output listening port: 2332
    8. Terminal I/O port: 2333
    9. Accept remote connection: localhost only
    10. Generate logfile: off
    11. Verify download: on
    12. Init regs on start: on
    13. Silent mode: off
    14. Single run mode: on
    15. Target connection timeout: 0 ms
    16. ------J-Link related settings------
    17. J-Link Host interface: USB
    18. J-Link script: none
    19. J-Link settings file: none
    20. ------Target related settings------
    21. Target device: STM32F303CB
    22. Target interface: SWD
    23. Target interface speed: 1000kHz
    24. Target endian: little
    25. Connecting to J-Link...
    26. J-Link is connected.
    27. Firmware: J-Link STLink V21 compiled Jun 26 2017 10:35:16
    28. Hardware: V1.00
    29. S/N: 774801057
    30. Checking target voltage...
    31. Target voltage: 3.30 V
    32. Listening on TCP/IP port 2331
    33. Connecting to target...
    34. Connected to target
    35. Waiting for GDB connection...Connected to 127.0.0.1
    36. Reading all registers
    37. Read 4 bytes @ address 0x00000000 (Data = 0x2000A000)
    38. Read 2 bytes @ address 0x00000000 (Data = 0xA000)
    39. Received monitor command: speed 1000
    40. Target interface speed set to 1000 kHz
    41. Received monitor command: clrbp
    42. Received monitor command: reset
    43. Resetting target
    44. Received monitor command: halt
    45. Halting target CPU...
    46. ...Target halted (PC = 0x0000029C)
    47. Received monitor command: regs
    48. R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
    49. R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
    50. R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
    51. R12= 00000000, R13= 2000A000, MSP= 2000A000, PSP= 00000000
    52. R14(LR) = FFFFFFFF, R15(PC) = 0000029C
    53. XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000
    54. CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
    55. Reading all registers
    56. Read 4 bytes @ address 0x0000029C (Data = 0xF7FFB508)
    57. Read 2 bytes @ address 0x0000029C (Data = 0xB508)
    58. Received monitor command: speed auto
    59. Select auto target interface speed (2000 kHz)
    60. Received monitor command: flash breakpoints 0
    61. Flash breakpoints disabled
    62. Received monitor command: semihosting enable
    63. Semi-hosting enabled (Handle on BKPT)
    64. Received monitor command: semihosting IOClient 3
    65. Semihosting I/O set to TELNET and GDB Client
    66. Read 4 bytes @ address 0x0000029C (Data = 0xF7FFB508)
    67. Downloading 928 bytes @ address 0x00000000 - Verified OK
    68. Downloading 40 bytes @ address 0x000003A0 - Verified OK
    69. Downloading 4096 bytes @ address 0x000003D0 - Verified OK
    70. Downloading 4096 bytes @ address 0x000013D0 - Verified OK
    71. Downloading 4096 bytes @ address 0x000023D0 - Verified OK
    72. Downloading 4096 bytes @ address 0x000033D0 - Verified OK
    73. Downloading 4096 bytes @ address 0x000043D0 - Verified OK
    74. Downloading 4096 bytes @ address 0x000053D0 - Verified OK
    75. Downloading 4096 bytes @ address 0x000063D0 - Verified OK
    76. Downloading 4096 bytes @ address 0x000073D0 - Verified OK
    77. Downloading 2011 bytes @ address 0x000083D0 - Verified OK
    78. Downloading 8 bytes @ address 0x00008BAC - Verified OK
    79. Downloading 1548 bytes @ address 0x00008BB4 - Verified OK
    80. Comparing flash [....................] Done.
    81. Writing register (PC = 0x 188)
    82. Read 4 bytes @ address 0x00000188 (Data = 0xB083B500)
    83. Received monitor command: clrbp
    84. Received monitor command: reset
    85. Resetting target
    86. Received monitor command: halt
    87. Halting target CPU...
    88. ...Target halted (PC = 0x0000029C)
    89. Received monitor command: regs
    90. R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
    91. R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
    92. R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
    93. R12= 00000000, R13= 2000A000, MSP= 2000A000, PSP= 00000000
    94. R14(LR) = FFFFFFFF, R15(PC) = 0000029C
    95. XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000
    96. CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
    97. Reading all registers
    98. Read 4 bytes @ address 0x0000029C (Data = 0xF7FFB508)
    99. Starting target CPU...
    SEGGER Log for Nucleo-F303RE (not working):
    1. Could not connect to target.
    2. Please check power, connection and settings.SEGGER J-Link GDB Server V6.60f Command Line Version
    3. JLinkARM.dll V6.60f (DLL compiled Jan 20 2020 16:15:17)
    4. Command line: -if swd -device STM32F303CB -endian little -speed 1000 -port 2331 -swoport 2332 -telnetport 2333 -vd -ir -localhostonly 1 -singlerun -strict -timeout 0 -nogui
    5. -----GDB Server start settings-----
    6. GDBInit file: none
    7. GDB Server Listening port: 2331
    8. SWO raw output listening port: 2332
    9. Terminal I/O port: 2333
    10. Accept remote connection: localhost only
    11. Generate logfile: off
    12. Verify download: on
    13. Init regs on start: on
    14. Silent mode: off
    15. Single run mode: on
    16. Target connection timeout: 0 ms
    17. ------J-Link related settings------
    18. J-Link Host interface: USB
    19. J-Link script: none
    20. J-Link settings file: none
    21. ------Target related settings------
    22. Target device: STM32F303CB
    23. Target interface: SWD
    24. Target interface speed: 1000kHz
    25. Target endian: little
    26. Connecting to J-Link...
    27. J-Link is connected.
    28. Firmware: J-Link STLink V21 compiled Aug 12 2019 10:29:20
    29. Hardware: V1.00
    30. S/N: 775245505
    31. Checking target voltage...
    32. Target voltage: 3.30 V
    33. Listening on TCP/IP port 2331
    34. Connecting to target...
    35. WARNING: CPU could not be halted
    36. Halting target device failed. Trying again with reset
    37. WARNING: CPU could not be halted
    38. WARNING: CPU could not be halted
    39. WARNING: CPU could not be halted
    40. WARNING: CPU could not be halted
    41. WARNING: CPU could not be halted
    42. ERROR: Failed to halt CPU.
    43. WARNING: CPU could not be halted
    44. Failed to halt target device on connect
    45. ERROR: Could not connect to target.
    46. Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
    47. Shutting down...
    When I use the J-Link Commander I get a similar message that the CPU could not be halted.
    I tried to upload the Blinky example to the on-board STM32F303RE controller and it works fine.
    What could be causing this behaviour? Any help would be appreciated.
    The post was edited 2 times, last by s7iVuR ().
    Please note that the usage of the J-Link on the ST board in such way is a license violation and illegal.
    You can read the license agreement in the daily pop-up and here:
    segger.com/products/debug-prob…nk-on-board/#terms-of-use
    Since you seem to be using this setup in an educational purpose please find information about our official products for educational use here:
    Small/cheaper version: segger.com/products/debug-prob…k/models/j-link-edu-mini/
    More robust version with more features: segger.com/products/debug-probes/j-link/models/j-link-edu/
    Pros:
    - Use is legal for private and educational purposes.
    - Cheaper than most evaluation boards, so it should be affordable for any budget.
    - Supports all our supported devices.
    Please do not open further threads regarding this topic or we will have to remove you from this forum.
