[bug]ozone v3.10b can not get the correct initial​ PC based iar7.10 *.out
    • [bug]ozone v3.10b can not get the correct initial​ PC based iar7.10 *.out
      1. It is possible to debug the same * .out (created by iar 7.10) with the ozone project created by v2.70, but the ozone project created by v3.10 is wrong.
      2. The screenshot below shows that they got a different PC and v2.70 got the right PC.
      3. The source code shows different content inside the two projects.
      4. Elf.GetEntryPointPC (), this api cannot get the correct initial pc, at least * .out created by iar 7.10.
      1. void AfterTargetDownload (void) {
      2. unsigned int SP;
      3. unsigned int PC;
      4. unsigned int VectorTableAddr;
      5. VectorTableAddr = Elf.GetBaseAddr();
      6. if (VectorTableAddr == 0xFFFFFFFF) {
      7. Util.Log("Project file error: failed to get program base");
      8. } else {
      9. SP = Target.ReadU32(VectorTableAddr);
      10. Target.SetReg("SP", SP);
      11. PC = Target.ReadU32(VectorTableAddr + 4);
      12. Target.SetReg("PC", PC);
      13. }
      14. }
      2. unsigned int SP;
      3. unsigned int PC;
      6. if (VectorTableAddr != 0xFFFFFFFF) {
      7. SP = Target.ReadU32(VectorTableAddr);
      8. Target.SetReg("SP", SP);
      9. } else {
      10. Util.Log("Project file error: failed to get program base");
      11. }
      12. PC = Elf.GetEntryPointPC();
      13. if (PC != 0xFFFFFFFF) {
      14. Target.SetReg("PC", PC);
      15. } else if (VectorTableAddr != 0xFFFFFFFF) {
      16. PC = Target.ReadU32(VectorTableAddr + 4);
      17. Target.SetReg("PC", PC);
      18. }
      19. }
      Could you provide your .out file for reference?
    • New
      1. Thank you for your attention.
      2. Please change the file name "project.out.bin" to "project.out".
      3. The same problem was encountered again today. This time in MDK.
      4. The problem caused the program to skip "SystemInit ()".
      5. After I used Target.ReadU32 (VectorTableAddr + 4) to get the PC value, the problem was solved.
      The post was edited 1 time, last by caowent ().
