Setting RTT control block when not automatically found
    • Setting RTT control block when not automatically found
      I am debugging an externally built executable in Embedded Studio, my setup is NXP MIMXRT1060-EVK board + JLink.
      I interact to this application with Putty, through RTT.
      I saw in another post in this forum that I can disable RTT redirection to the Debug Console, fine.
      The problem is that when I disable it throug "Debugger"->"RTT Enable"-> "No" setting,
      JLink doesn't locate _SEGGER_RTT anymore.
      It is located ad address 0x20280670, and if I specify it manually in the JLink settings, or through a custom jlink-script it works fine.
      My question is, how can I manage to have it automatically found, even if it will be further relocated (via _SEGGER_RTT symbol)?
      with GDB, I would have used
      eval "monitor exec SetRTTAddr %p", &_SEGGER_RTT
      as an itialization command.
      Thank you
      The post was edited 2 times, last by ballotz ().
      The reason why the RTT Control Block cannot be found is most likely that it is placed outside of the RAM area specified in out DLL.
      You can (as you already know) specify, the address to the DLL so it does not need to find it.
      You can also do this via TELNET, with for example in putty.
      Please find an article about how to do this here:
      wiki.segger.com/RTT#SEGGER_TELNET_Config_String
      Please make sure you use the latest J-Link version, since this is a very recent feature.
      Does this resolve the issue?
      On a side note:
      You can also you the J-Link RTT Viewer in attach mode (connect to existing session) for this purpose. It lets you set the Address via the Configuration Dialog.
      thanks for your answer,
      I didn't know about this new feature, I'll give it a try,
      though it is not clear to me how can be putty or a telnet client be aware of the _SEGGER_RTT symbol,
      that string can be sent form the program itself?
      Just a note about ES, when "Debugger"->"RTT Enable" is set to "Yes",
      RTT works even if it is located at 0x20280670, without specifying additonal settings.
      Maybe disabling RTT redirection to the Debug Console disables ES auto-locating of RTT too?
      At the moment I solved the issue relocating _SEGGER_RTT to DTCM, so it can be automatically found.
      Thank you,
      Alessio
    • Hi Alessio,
      Sorry if my explaination wasn't clear enaugh:
      The Config string has to be sent from the host system, not the target.
      So you send it via e.g. putty within 100ms after esablishing the connection between putty and the TELNET channel.
